99 civic si problem starting... New swap
Just took out my b16 obd2 and put in a gsr turboed obd1.
Everything is hooked up right
Gets gas
Gets Spark
Has compression
Tried another ecu
The starter is fine
Wiring is all good
fuses are good
It don't sound like it wants to start at all.. Its like its just spinning, I don't get it
What the hell could it be?
Gets gas
Gets Spark
Has compression
Tried another ecu
The starter is fine
Wiring is all good
fuses are good
Go cry to momma
Re: 99 civic si problem starting... New swap
Gets gas
Gets Spark
Has compression
Tried another ecu
The starter is fine
Wiring is all good
fuses are good
Gets gas
Gets Spark
Has compression
Tried another ecu
The starter is fine
Wiring is all good
fuses are good
Go cry to momma
What ecu are you running? If it's an obd2, that's most likely your problem. The ecu would be looking for that crank sensor. Somebody correct me if I'm wrong, it's been one of those days...
