99 Civic SI - 5th Gear Problems!
Old 11-01-2008, 01:23 PM
95MustangGT's Avatar
95MustangGT has disabled reputation
Default 99 Civic SI - 5th Gear Problems!
Lately my car has been popping out of 5th gear! It used to do it rarely but lately it has been doing it quite a bit, mostly when i hit bumps or at higher speeds. I went under the car and couldn't find a problem, stabilzer was in tight and the bushing on the tranny was good. I really didn't take nothing apart down there to look. Well i pulled out the center console today..expecting to see a bushing but i didn't. I guess i have to go under the car and pull the stabilzer out? Could it even be the bushing? When the car is in gear, i can move it around quite a bit like it is in nuetral. Well today after take the center console out i went on a drive, it didn't pop out of gear during the drive but i noticed the stabilzer moves quite a bit when hitting the gas. I understand its a FWD car and it's going to move..but i don't think moving up about roughly a inch forward is normal. So i got back and checked out the motor mounts out and noticed when i revved the motor from the TB the driver side motor mount nuts would MOVE. They were really loose, i tightned them and went on another drive and nothing happened. But it doesn't do it all the time!
What else could it be? Im new to these hondas if nobody knows about me yet, i used to own a 5.0!
Could it possibly be the clutch not letting me engage it all the way into 5th? But if it was the clutch it would do that in all the gears correct?
Bushing?
Shifter?
I've got to get this fixed, i live in Florida now but im about to move back to Virginia and i need it fixed! Can't drive 1k miles in 4th gear!!!!!
95MustangGT is offline
Old 11-01-2008, 01:40 PM
Still spinnin'
Thurm@n's Avatar
Default Re: 99 Civic SI - 5th Gear Problems!
My car has the same problem except it's my 2nd gear. I gotta snatch it for it to go in w/o grinding or popping out below 5k rpm. But if I shift to 2nd at 5k or higher it'll go in like normal....didn't mean to thread jack
Thurm@n is offline
Old 11-01-2008, 01:50 PM
Old School Beast
PoS hYbRiD's Avatar
PoS hYbRiD is infamous around these partsPoS hYbRiD is infamous around these partsPoS hYbRiD is infamous around these partsPoS hYbRiD is infamous around these partsPoS hYbRiD is infamous around these partsPoS hYbRiD is infamous around these partsPoS hYbRiD is infamous around these partsPoS hYbRiD is infamous around these partsPoS hYbRiD is infamous around these partsPoS hYbRiD is infamous around these partsPoS hYbRiD is infamous around these parts
whens the last time you checked or changed tranny fluid. I would also check your mounts. If the shifter is moving noticeably when your shifting or letting out the clutch in 1st then you have a bad motor mount.
PoS hYbRiD is offline
Old 11-01-2008, 07:44 PM
Well checked the mounts out earlier, driver side was loose! When reving the motor from the TB the nuts were spinning off! Tightened them up, drove all day today and nothing happened! But we will have to see!
ALso i do need to check the fluid anyways, what is a good tranny fluid to put in there?
Old 11-01-2008, 09:13 PM
00si's Avatar
00si is infamous around these parts00si is infamous around these parts00si is infamous around these parts00si is infamous around these parts00si is infamous around these parts00si is infamous around these parts00si is infamous around these parts00si is infamous around these parts00si is infamous around these parts00si is infamous around these parts00si is infamous around these parts
drain old fluid and use GM syncromesh its a little more expensive but it works better
00si is offline
Old 11-02-2008, 05:11 AM
braap braap
Jarrod's Avatar
Honda MTF.
Nothing else.
Jarrod is offline
Old 11-02-2008, 05:38 AM
Huntin Dropa ForLife
RPRacing's Avatar
RPRacing has disabled reputation
what part of Florida? i'll come get you. you pay my way, i'll tow you back here and help y ou move your crap. you provide all expenses and buy any parts needed to fix your car. I'll provide all free labor
RPRacing is offline
Old 11-02-2008, 06:58 AM
Old School Beast
PoS hYbRiD's Avatar
Originally Posted by Jarrod
Honda MTF.
Nothing else.
Couldnt have said it better myself.
Old 11-03-2008, 04:21 PM
haha im in Port St Lucie, aka Port St Useless.
Old 11-03-2008, 04:50 PM
RPRacing's Avatar
860miles. 13.5 hours each way. i'm down
RPRacing is offline
8====D
Engine / Exhaust / Drivetrain
03-03-2009 01:44 PM
TheGr8one757
03-23-2004 07:23 PM
Quick Reply: 99 Civic SI - 5th Gear Problems!
