96-00 rear disc conversion questions
Old Feb 3, 2005 | 03:54 PM
Iceman05's Avatar
I <3 BOOST
Iceman05 is an unknown quantity at this point
Default 96-00 rear disc conversion questions
ok, im thinking about doing a rear disc conversion but i had a few questions. first of all let me state that my car is a non-ABS 98 Civic EX. first question: Can i use my stock LCAs or do i need ones from a teg/SI? second: Do i need a SI or Teg Prop. Valve? -if so, which one? third: Can i use my OEM brake lines? (the reason i ask is bc i have some Goodridge SS lines, but they're for 96-00 EXs, not the SIs). thanks in advance for the help!
Old Feb 3, 2005 | 04:37 PM
GIMMEAN"H"'s Avatar
cibic weetec
GIMMEAN"H" has a reputation beyond reputeGIMMEAN"H" has a reputation beyond reputeGIMMEAN"H" has a reputation beyond reputeGIMMEAN"H" has a reputation beyond reputeGIMMEAN"H" has a reputation beyond reputeGIMMEAN"H" has a reputation beyond reputeGIMMEAN"H" has a reputation beyond reputeGIMMEAN"H" has a reputation beyond reputeGIMMEAN"H" has a reputation beyond reputeGIMMEAN"H" has a reputation beyond repute
Default Re: 96-00 rear disc conversion questions
first of all, you need to use your factory lca's. the teg ones will give you positive camber out the azz (like 30+ degrees )
second, you need to get a proportioning valve from either a 94-01 teg or 99-00 si.
third, you will need to use the disc brake lines.
also, you need to get the teg or si e-brake cables.
Old Feb 3, 2005 | 05:47 PM
Iceman05's Avatar
I <3 BOOST
yea, i know bout the cables. so there's no way i can use these lines? damn
00si
Nov 12, 2008 06:05 PM
b16 snatch
Jan 30, 2008 06:05 AM
BrokeAssCrix
Nov 22, 2007 02:26 PM
chucha
Mar 8, 2006 06:29 PM
Dang Yo
Aug 15, 2003 11:55 AM
