95 civic eg 1.6 v-tech issue???
from what i was told when i bought the car, it over heated and shut off, would not start back up sat for 6 months...
when i got it home it started and ran for a good 1.5 seconds at 800rpm and shut off, would not start back up, so i just went ahead and replaced...so there was no guessing on a blow head gasket
- head gasket, timing belt, water pump, oil change, spark plugs, radiator
- added 2 gls of gas to an empty tank and removed fuel line from rail to purge threw new gas
- removed fuel rail and injectors and gave them a great cleaning while i was at it.
now that its all fresh, i try to start it and it just turns over, im getting a bit of smoke out of the valve cover breather while its turning over if that matters or not...
im getting spark from each cylinder....
when you over heat a 95 civic is there anything else that may be part of this like sensors that would prevent it from starting...be sides the overheating issue, possibly the main fuel relay acting up, the car did sit for 6 months ???
Re: 95 civic eg 1.6 v-tech issue???
sounds like your cam timing is off. Triple check. Thought mine was 100% but I was wrong and I had the same symptoms.
You need to top off your V-TECH fluid. It's difficult.
Troll & Run
is the phone on the hook?
baller/dickbutt#69
im not as stupid as you try to make me sound, lol, heads not warped, checked, but thanks for your common sense..... but got it running, come to fine out needs new rings or pistons cause possible ring lands are busted, blowing quite a bit of smoke....
ConflictedFelon
Closing because problem is apparently solved.
