93 mercedes benz alarm and door lock problem
fixed please delete
Re: 93 mercedes benz alarm and door lock problem
it probably one of the lock actuators that are stuck/broken and not allowing the central locking system to actually lock the doors
highend cars /highend problems /highend money |
If, on the other hand, the door locks do lock, it's probably the tow sensor. This was a weak point in the W126, so it's likely a weak point in the W140 too. A cheap solution is to just unplug the alarm system's box.
Originally Posted by marlinspike
(Post 6819412)
where is the tow sensor, and the alarm system box?
Not sure on the tow sensor, but the alarm system box is near the fuse box in the trunk. It could also be one of the window sensors...or one of the many other sensors.
Fair warning, while I think the central locking will still work with the control box disconnected, you won't be able to use the remote if yours has the remote, and the mechanism that stops the windows from going up when something is in the way won't work (I think). |
all the doors only lock if done manually and dont lock all with the key in door and auto down on windows dont work only the right rear does
Eh, disconnect the box (it's made by Becker) and see where that gets you. It's on the right side of the trunk behind the carpeting.
ok thanks for all the help im going to try all of that tomorrow and see if it fixes the problem
