93 Del Sol Rev Problem!!!
Old Dec 9, 2007 | 04:29 PM
xXThat GuyXx's Avatar
xXThat GuyXx has disabled reputation
Default 93 Del Sol Rev Problem!!!
Hey Guys,
Lookin for any help i can get on this.
When you turn the car on it turns a rev limiter on and u flip the key back and turn back on and it clears it and drives fine.
Now I originally thought thay it may be a Vacuum Line, but if it were that it would been there after the car was turned on. Now I am thinking that it has something to do with a sensor.
It does have a b16 swap on it if that makes a difference.
Help Please!!!
Thanks a lot.
Old Dec 9, 2007 | 05:19 PM
jdmteg18's Avatar
jdmteg18 is an unknown quantity at this point
Default Re: 93 Del Sol Rev Problem!!!
Originally Posted by xXThat GuyXx
Hey Guys,
Help Please!!!
Thanks a lot.
damn dude,i have no idea what your talking about. try re-writing your post including DETAIL,and i could possibly help. or if your close,id be willing to come take a look at the car. but reading your post,i have no idea what your trying to say.
Old Dec 9, 2007 | 06:01 PM
Yell88CRXsi's Avatar
Team Ultraspeed
I think what he is trying to say is...when he starts the engine it runs. When he tries to step on the gas instead of it reving up to rev limiter, he hits the limp mode limiter which should be 3000 - 3500 rpms.
If what I am saying is correct, then you ARE throwing a code/codes and before anyone can help you, you need to find out what they are. There are only a few things that will throw you into limp mode and they are all electrical.
Old Dec 9, 2007 | 06:12 PM
how severe would limp mode be to the engine?
Old Dec 9, 2007 | 06:59 PM
jdmteg18's Avatar
limp mode wont do anything to an engine,its there to PREVENT damage to an engine.Limp mode is the computers way of running in "safe" mode,it basically sees a problem (hence a faulty sensor,mis-fire leading to a thrown code,faulty wiring,etc) and prevents the motor from reving past 3500. Like said,if your computer is running in limp mode,your going to be throwing a code. Find out what code your throwing and we can go from there. if you need to know how to check and get the code,PM me.
Old Dec 9, 2007 | 08:15 PM
DAintegra90's Avatar
DAintegra90 has disabled reputation
+1 but it wont always throw a code if its in limp mode, i had a 240 do it and it ended up being the maf.
Old Dec 10, 2007 | 12:16 PM
but when the car is switched off then back on the limp mode is gone and the check engine light goes away
Old Dec 10, 2007 | 02:16 PM
Team Ultraspeed
Maybe it's one of the sensors and whebn powered, it warms up it works?
Once again, I really need to know what code you are throwing to help.
If the "Check Engine" light is on...99.99% chance there's going to be a code. You have to jumper it out to get the code to show via the check engine light.
ekay4
Jan 23, 2009 02:56 PM
gmacarize
Want to Buy / Trade ARCHIVE
Sep 12, 2008 11:11 PM
tricknology
Aug 2, 2007 02:40 PM
