93 da rear lights leaking water in trunk
on my da the tail lights are leaking and after the last rain i had 3 inches of water in my trunk would it be better to replace the lights itself or just get new seals are a easy fix someone please tell me where i can get some...thanx in advance
throwbAcura
Re: 93 da rear lights leaking water in trunk
Get new gaskets then make sure the weatherstrip around your hatch is good. Chances are you need to replace that as well.
If you open your hatch and find water or dirt in the left and right channels the hatch needs fresh rubber.
idk if i need rubber 4 the hatch i took the covers inside the trunk off poured a little water along the sides and water was going through the tails right to where the spare is located
bigassturbo
Want to Buy / Trade ARCHIVE
09-02-2008 07:23 PM
