93 coupe boost problem
Old Nov 6, 2006 | 04:20 PM
Ross's Avatar
Ross is an unknown quantity at this point
Default Re: 93 coupe boost problem
what are you controling the 390cc injectors with? what heat range plug are you running? What are you using to moniter air fuels? Also take the MSD box out it is not needed and is prone to fail. How old is the cap and rotor? Are you sure your boos guage is accurate?
Old Nov 6, 2006 | 05:54 PM
spider228's Avatar
N/A
spider228 has a reputation beyond reputespider228 has a reputation beyond reputespider228 has a reputation beyond reputespider228 has a reputation beyond reputespider228 has a reputation beyond reputespider228 has a reputation beyond reputespider228 has a reputation beyond reputespider228 has a reputation beyond reputespider228 has a reputation beyond reputespider228 has a reputation beyond reputespider228 has a reputation beyond repute
im using the SAFT II to controll the injectors, my buddy Dave (aka Turbo Dave) set the safc for me. im using an autometer air/fuel gauge, and autometer boost gauge, i bought them both about 2 months ago brand new. the cap and rotor are about 3 months old. not sure what heat range the plugs are. where can i get a good set of plugs from.
Old Nov 6, 2006 | 06:18 PM
GaRn's Avatar
Alrighty,
Here is what I would recommend..
Please put a lower spring in there for now or don't go around boosting it,
Sell your SAFC II on ebay, as well as your FMU, and buy a socketing kit, diy or get someone to socket it for you, download CROME and buy a chip burner for $45 on ebay. Thats like $65 so far.. you will MAKE money off of selling that stuff, and have 1000x's better fuel management... Then get a wideband, and tune it..
That is what I would do, but almost 9 psi on an FMU is not my idea of fun, and I would get on solid ground first before trying to figure anything else out.
Old Nov 6, 2006 | 06:45 PM
Dang Yo's Avatar
Justa lil 6
Dang Yo is a jewel in the roughDang Yo is a jewel in the roughDang Yo is a jewel in the roughDang Yo is a jewel in the roughDang Yo is a jewel in the rough
are you running a missing link or any check valves?
Old Nov 6, 2006 | 06:52 PM
spider228's Avatar
N/A
8 check valves
Old Nov 7, 2006 | 10:51 AM
zappas's Avatar
been around awhile.
zappas zappas zappas zappas zappas zappas zappas zappas zappas zappas zappas
8 check valves
there is your problem right there.
check valves are shit.
i gaurantee if you get either ems. or a missing link...you will not have an issue.
I had this exact same problem once before..kept adding valves, it doesnt work.
Old Nov 7, 2006 | 11:16 AM
spider228's Avatar
N/A
i dont have a throttle body mounted sensor, mine is on the firewall.
Old Nov 7, 2006 | 11:33 AM
zappas's Avatar
been around awhile.
we'll whatever the unit is for your car you need to get...instead of check valves.
I am 99.9% sure that is your problem.
Old Nov 7, 2006 | 11:44 AM
spider228's Avatar
N/A
it only does it when im full pedal
Old Nov 7, 2006 | 11:48 AM
zappas's Avatar
been around awhile.
yea, I understand...I delt with this same issue, full pedal is full boost..the checkvalves cannot handle it, the minute I converted to the missing link, the problem was gone.
