92' Civic headlight...HELP
i have a 92 civic... low beam does not work, high beam does.... all fuses were replaced, relays are all ok... i know its the stock light switch... but i wanted to know if there is any way to use a switch that you would use for fogs as replacement? would it be easy? if you know how to do it, how much you would you want? thanks for the help
Why not just buy a new switch or get a used stalk from the junkyard? Don't rig something instead of fixing it the right way when it's so easy to repair.
