91 Civic Sedan electrical issue
i pooped a squirrel
Re: 91 Civic Sedan electrical issue
Ok.
-confirmed continuity between circuit ground and body ground
-confirmed continuity between faulty wire and circuit/body ground
-with pedal depressed read 0v coming from faulty wire.
-measured 0v between circuit ground and body ground
-measured .25ohms between circuit ground and body ground
Again, running out of ideas as to what it could be
Ok.
You already know that the switch is good, because the other taillight works. The switch has a 2 pin connector, so somewhere there is a junction that breaks the single wire from the brake switch into 3 different wires for the left, right, and CHMSL (third brake light). You know the other two lights that connect there are functional, and one isn't. Find that junction and start from there.
i pooped a squirrel
Update:
So earlier in the week i replaced the brake light switch, just because i had a brand new one. No change. Took the time today to strip more of the wire loom away and found the junction that brakes the single power feed into 2 feeds (i think theres another junction in the trunk that runs the third brake light). I traced the bad wire from the plug into the junction and saw no broken insulation, burn marks, or anything else to indicate exposed copper or a short. I figured there was maybe an issue within the insulation that hadnt made its way through, so i replaced that entire section of wire and still dont have a functioning brake light.
Out of ideas completely. Might light the car on fire
Update:
I told you the brake light switch wasn't the problem, because the other tail light works perfectly fine.
i pooped a squirrel
Now that you know where that junction is, test back from the tail light to that junction, and test the ground as well if you haven't already. This is going to be a simple problem and you're going to kick yourself when you find it.
i figured since i already had one, might as well do it lol. best case, it somehow fixed the issue. worst case i have a new switch
All your problems can be solved with a multimeter.
Keep pushing, the problem is right there but you haven't seen it yet...
i pooped a squirrel
I've been using a multimeter! At this point the only thing that makes sense is the plug needing to be repinned
If you test from the connector pin on the bulb side to that wire splice, it sounds like you'll find a break somewhere around there.
