89 crx with 91 ls swap no power
Old Sep 16, 2006 | 09:49 AM
slimb's Avatar
slowest member
slimb is infamous around these partsslimb is infamous around these partsslimb is infamous around these partsslimb is infamous around these partsslimb is infamous around these partsslimb is infamous around these partsslimb is infamous around these partsslimb is infamous around these partsslimb is infamous around these partsslimb is infamous around these partsslimb is infamous around these parts
Default 89 crx with 91 ls swap no power
car is getting power to the coil, main relay, and power to the ecu but ecu wont flash. tried ecu in another car worked fine. car will turn over not getting spark at spark plugs. volt meter is reading 12 volts at coil
Old Sep 17, 2006 | 09:38 PM
atmdc's Avatar
やくざに成りたい
atmdc has disabled reputation
Default Re: 89 crx with 91 ls swap no power
did you do an mpfi swap at the same time of the swap?
Old Sep 18, 2006 | 07:44 AM
slimb's Avatar
slowest member
swap is 2 years old. car was running turned it off for 20 minutes got back in and wouldnt start
resolution
Feb 7, 2007 02:31 PM
