5 Speed Swap
5 Speed Swap
I am thinking about swapping my 96 civic ex auto to a 5 speed. I was just wondering what all i need to swap out this and a general idea on how much it would cost to swap.
Eric Demo
Eric Demo
Re: 5 Speed Swap
the easiest way to do it is to find a 5 speed shell of your car from a junkyard wrecked in the rear an pull center console shifter clutch pedal assembly shift linkages cables are cheap enough to just go to the parts store for but you can prolly do all that for a couple hundred pretty easy thing to do also just a couple holes an mounting.... if you ever have a problem with the clutch feeling spongy afterwards check on the firewall because some of the auto matic cars are not reinforced enough for the 5 speed
