240sx! Need engine help asap! Blown motor...
So i was driving down i264 west and was on my way home, then all of a sudden smoke started coming into the car and coming out the engine. I pull over on the emergency lane and tried to find out what happened. I have a 89' 240sx with a red top sr20det swap. Turns out, i think one of my rod bearing went out because under the throttle body and next to the starter theres like a bullet hole that went from where the top straight through the bottom to so i could see the ground pretty much. I ended up getting it towed. anyone have any ideas on what i can do other than getting a new engine.
New swap
2 days later...
New swap
2 days later...
baller/dickbutt#69
Re: 240sx! Need engine help asap! Blown motor...
not really. idk how this even happened. im running on stock boost. 7lbs thats it and was driving normally and all of a sudden smoke everywhere
yeah thats what this vdot guy was saying too. its a perfect shot from top to bottom. do you know any place i can get a long block?
a lot of JB weld lol
If looking for a nice block http://www.z1motorsports.com/240sx/p...tdagkihghaoc72
Just a cheap replacement http://www.jgy.cc/motors.htm or http://www.google.com/products?q=SR20det+Engine+&aq=f
Need someone to do it for you http://www.jspec.com/frontclips.html or me, maybe.
Trill Shit
did u hammer out ur oil pan and clean ur oil pick up out before u swapped it? if u pull ur pan off u'll probably find that ur oil pick up swallowed itself from oil starvation, u need a long block, i'd check the cam journals to make sure the head is ok
Yeah that's what a figured what happened. there was a little dent but i think thats what made the car give in. I talked to danny and gonna try and get a longblock and just swap it all out.
