2000 Civic power lock issue
Old 10-28-2009, 01:04 PM
disheeki546's Avatar
disheeki546 disheeki546 disheeki546 disheeki546 disheeki546 disheeki546 disheeki546 disheeki546 disheeki546 disheeki546 disheeki546
Default 2000 Civic power lock issue
So, I can be pretty lazy sometimes, and this issue is a good example of that. Almost a year ago this problem started with my power door locks that I can't really figure out because I just don't know enough about how it is wired and to be honest, haven't cared enough.
I'll explain the locks on my car for those who may not be familiar. The lock on the driver door has a manual switch and the power switch. When you lock and unlock the manual one on the driver side it will lock and unlock the passenger side also, which only has the manual switch. When you lock and unlock the manual switch on the passenger door it does not operate the driver side. When the car is started, it will wait a second then lock both doors. When it is turned off, it immediately unlocks both.
The problem I'm having is when the car is started, the doors will lock like they are supposed to, wait another couple seconds then unlock again. You can use the manual switch on the driver door and it will lock both sides, but as soon as you let off it unlocks again. Same goes for the power switch. If the car is off, you can lock the driver side with the manual switch and it will lock both sides and stay like it is supposed to. Even when it's off the power switch will do the same thing where it locks then unlocks again.
To add to it I noticed recently, though it may have always done it and I jsut noticed, when the car is on and you operate the power windows either up or down and locks will act up and try to lock, but obviously don't like to do that, so they unlock again.
Any suggestions? Anybody? I don't really know where to start.
Thanks, Mike.
disheeki546 is offline
Old 10-30-2009, 12:11 PM
Default Re: 2000 Civic power lock issue
anybody?
Old 11-04-2009, 12:01 PM
pumb
Old 11-05-2009, 10:02 PM
johncarlito's Avatar
johncarlito has disabled reputation
ok is the car 2dr or 4dr?? are power locks oem or aftermarket???? does the car have an alarm system???? need more details about the car to help !!
johncarlito is offline
Old 11-06-2009, 11:38 AM
civic si only came 2 door. power locks came oem. it does have an alarm/keyless entry system that came on the car when i got it. could that alarm have gone bad or something causing this?
Old 11-06-2009, 03:44 PM
impound's Avatar
impound has disabled reputation
oem keyless?
impound is offline
Old 11-07-2009, 04:18 PM
yes they did come oem keyless, but this is an aftermarket alarm system that came with the car when i got it. it also has keyless entry.
Old 11-10-2009, 07:17 PM
for alarms/rmt-strts
EH3_SOHC's Avatar
EH3_SOHC has disabled reputation
your alarms fucked up buddy. im guessing its a DEI brand or an upper end autopage because there the only ones i know of that are sold in this area that have the lock when in motion feature. depending on what model i may be able to swap it out for you for a small cost. pm me if interested
EH3_SOHC is offline
madsteez
09-04-2009 10:26 PM
madsteez
07-23-2009 03:26 PM
madsteez
02-03-2009 10:42 AM
98honda
06-02-2006 11:36 AM
Quick Reply: 2000 Civic power lock issue
