1st gen crx motor swaps...
Does anyone have any info on how difficult it is to do a motor swap on the 1st gen crx. It is also carbureated. Anyone know how to make it fuel injected, and what all i would need to get from a injected crx. I am pretty sure i will need the gauge cluster cause it has a speed sensor and can i just grab the entire harness and manifold and swap it over?
heh...u guys dont know about the fieros we had =]
noreverseteg got a look at them...they arent a pos with a v8 in them. =]
actually they still are pos and yes they catch on fire...plus most of the car being plastic...oh well there is a reason why they stopped production after 88...because they are death traps
swapping in a ZC or B-series motor is pretty easy... for the ZC, you can get a "brown top", which has the correct mounts. HASport makes a mount kit to drop in B-series motors.. your big problem is the fuel system. Since your car is carbed, the whole fuel system will need to be replaced. Tank, lines, pump, etc... Coolest first gen I ever saw was a DX running a ZC motor with dual carbs... that's what I'd do...
Dan
(former owner of a Cammed, ZC powered first gen Si)
Dan
