1992 Civic w/ D16Z6...mysterious overheat problem
I <3 Hikki Chan!
Okay so this is a bone stock '92 Civic Hatch w/ a D16Z6 swap (car is automatic). It started mysteriously overheating a few months ago and it's been parked since and I haven't had the time to work on it. The situation is that the upper hose gets hot but the lower hose stays cold. Of course the gauge sensor is in the upper housing and the thermostat/fan switch is in the lower housing. It shows indications of no flow. The whole cooling system aside from the waterpump itself has been replaced. Hoses, sensors, radiator, thermostat, clamps etc. Someone pointed out that it's probably a blown head gasket. I thought that too but there's no signs of that happening.
Even with a blown head gasket if the water pump was circulating coolant the lower hose would get warm eventually correct? I've replaced the thermostat twice and still nothing. Should I try removing the thermostat?
Re: 1992 Civic w/ D16Z6...mysterious overheat problem
I couldn't even tell you. Antifreeze corrodes after a while. Maybe that could be it. when you took the hoses and thermostat off what did they look like?
The only thing that you haven't replaced is the part responsible for circulating the coolant.
Warm the engine up so the thremostat is open. Squeeze the upper hose and rev the engine. You should feel the pump add a little bit of pressure to the hose.
I <3 Hikki Chan!
With the engine running and the radiator cap open, if I rev the engine the coolant level does rise...that indicates a good water pump right?
