X-Force Varex Mufflers!!
Old Oct 16, 2008 | 06:26 PM
nismosentraqg18's Avatar
nismosentraqg18 has a little shameless behaviour in the past
Default X-Force Varex Mufflers!!
Hey I me and a couple of my buddies got together and we are starting to sell aftermarket parts for cars. Our company name is "XNiTune." We will have a website up soon. We are about to order a fairly large shipment of X-Force Varex mufflers which arn't forsale in the US anywhere. We will be the only retailer and we will sell them for the company's price of $450.Please let me know if you are interested! Heres a little info on the mufflers-
Varex muffler combines both the design technology of the stock muffler and the performance muffler into one single compact unit. A sophisticated butterfly valve mechanism is implemented to redirect the exhaust gas flow and vary between the two. For higher sound level, the exhaust flows are directed through the opening path and produces maximum power with a robust sound level (or the “sports car note”) and near-zero resistance. For lower sound level, the exhaust flows are directed through the chambered path (similar design with the stock muffler), and produces minimum sound level that gives you the best in-car comfort. Also, you are able to control the angle of the valve which can be adjusted to stop at any point between the sports mode and the silence mode. This gives you further freedom to set the optimal sound level according to your preference.
Sizes we sell-
VAREX Muffler Specification
Cannon VAREX:
Inlet size: 2.5” & 3”;
Barrel size: 7” O.D, 14” Long;
Tip size:4.5” O.D single wall tip;
Single Tip Oval VAREX:
Available Now.
Inlet Size:2.5" & 3";
Barrel Size: 6"X10";
Tip Size: 4" or 4.5" Round Double wall tip;
Twin Tip Oval VAREX:
Available Now.
Tip Size: Twin 3" O.D Double Wall Tip
Excellent Silence Effect: What makes the VAREX surpass other conventional Exhaust Control Valve(ECV) is that VAREX integrates the valve inside the muffler and actually work as a switch between the stock muffler and performance muffler. In Conventional ECV, it aims to block the exhaust gas flow in order to reduce sound volume. However, it can not fully block all gas flow because it still allows gases to escape around the butterfly valve when closed and therefore only partially blocks the exhaust gas flow inside the main exhaust tube. The sound wave can still push through the gap of the closed ECV (please remember that they cannot be completely closed, because the exhaust gases have no other exits and to fully close it is like completely blocking the exhaust tube). Therefore, the sound dampening effect of the conventional ECV design is significantly limited. With VAREX muffler, however, it can achieve near stock sound level not by blocking in the conventional way, but by completely redirecting the exhaust gas flow into the reflective chambered section, thus, changes the sound level back to near-stock volume whilst still maintaining smooth exhaust flow.
Simple Operation: You are able to adjust the sound level through a handy remote control pad, which gives you the convenience to do this anytime you want without getting out of your car.
Easy Installation: Directly bolt-on to most existing XFORCE exhaust systems, or custom fitted to a wide range of vehicles. No complex wiring/harness is required, since power supply is sourced from the cigarette lighter socket.
Maintaining Maximum Power Output: Most importantly, VAREX muffler is precisely engineered to ensure that when the Race Mode is switched on, it functions as a complete straight-through performance muffler with minimum back pressure.
The Varex muffler won 2007 product of the year by AutoSalon Magazine.
Two videos-
http://www.youtube.com/watch?v=K7jGYnhbQQU
http://www.youtube.com/watch?v=FNlgw1COym8
Old Oct 16, 2008 | 06:49 PM
rickhatesplinte's Avatar
rickhatesplinte has disabled reputation
Default Re: X-Force Varex Mufflers!!
buy my 90-91 crx guage cluster too!
Old Oct 17, 2008 | 02:50 PM
bump..
