WTT/FS Big brake setup gotta go..
Old Aug 25, 2007 | 06:55 PM
bigkshep's Avatar
bigkshep bigkshep bigkshep bigkshep bigkshep bigkshep bigkshep bigkshep bigkshep bigkshep bigkshep
Default Re: WTT/FS Big brake setup gotta go..
come with pads, rotors, and calipers?? would it need to be shimmed to put on at all??
Old Aug 25, 2007 | 09:16 PM
Samuels's Avatar
Samuels is infamous around these partsSamuels is infamous around these partsSamuels is infamous around these partsSamuels is infamous around these partsSamuels is infamous around these partsSamuels is infamous around these partsSamuels is infamous around these partsSamuels is infamous around these partsSamuels is infamous around these partsSamuels is infamous around these partsSamuels is infamous around these parts
Yeah pads,rotors,calibers. It is a bolt on affair on my EK the only modifying would need to be done is if you had 15" rims, then you have to shave the caliber slightly to fit them..
Old Aug 25, 2007 | 09:25 PM
Got_Boost99's Avatar
Got_Boost99 Got_Boost99 Got_Boost99 Got_Boost99 Got_Boost99 Got_Boost99 Got_Boost99 Got_Boost99 Got_Boost99 Got_Boost99 Got_Boost99
What wheels u used w/ this set-up?
Old Aug 25, 2007 | 09:27 PM
Samuels's Avatar
18's were used but you can run has small has a 16" wheel. You can run a 15" if you slightly grind the caliber down..
Old Aug 25, 2007 | 09:58 PM
How much u have to grind? I have SI wheels, and really looking to buy this brakes...
Old Aug 27, 2007 | 12:16 PM
Samuels's Avatar
FROM WHAT I've been told and read its not a ton but if you don't, the caliber will slightly rub the 15" rim
Old Aug 27, 2007 | 06:12 PM
cbrooks23453's Avatar
cbrooks23453 has disabled reputation
where are you located??
Samuels
Aug 18, 2007 02:06 PM
slither
Nov 7, 2004 01:33 PM
96blkcoupe
May 2, 2004 07:50 AM
