Parting 1996 GS-R 2 Door
Old Sep 25, 2008 | 04:39 AM
FSTASNTZ's Avatar
FSTASNTZ is an unknown quantity at this point
Default Parting 1996 GS-R 2 Door
Location: Apex, NC (15 minutes south of downtown Raleigh, NC)
Contact: Via PM on this site, AIM at FSTASNTZ or on my cell, 919.280.7174
Parting 1996 Acrua Integra GS-R 2 door. Car is red with black leather seats. Currently has 11590X miles, and has been my sister’s car since August 1996. Short block was rebuilt 6k miles ago with Eagle rods and Wiseco pistons.
The following parts are sold as of 11/16:
Leather seats
Back half of Center console with arm rest
ECU kick panel
Upper Steering column cover
Factory floor mats
Factory Cat Back Exhaust
Driver's Hub/upright/spindle
Transmission
Passenger Side Headlight
Rear Tunk/Cargo cover
Front Sway Bar
Gauge Cluster
Clock spring
Wheels & Tires
Right Front lower control arm
Left front lower control arm
Rear spoiler
HVAC controls
Random Tech High Flow Cat
Front Calipers
Rear Trunk Carpet
Ashtray/lighter insert
Passenger side door shell
Passenger side door panel
Front turn signal pair
PS Rack w/Inner tie rods & ball joints
Short Block assembly
Driver's Door Panel
Left rear inner panel w/speaker cover
Rear trunk panel
Right rear inner panel w/speaker cover
Glove box
Dash Shell
Front center console with shift boot
Black main floor carpet
The following parts were damaged and are not for sale:
Floor Mats
Driver's fender
Parts are available for local pick up or can be shipped at buyer's expense.
Old Sep 25, 2008 | 04:46 AM
mgs1098's Avatar
II Always
mgs1098 mgs1098 mgs1098 mgs1098 mgs1098 mgs1098 mgs1098 mgs1098 mgs1098 mgs1098 mgs1098
Default Re: Parting 1996 GS-R 2 Door
Sent you a text..
Alan
757-319-3095
Old Sep 25, 2008 | 06:41 AM
FSTASNTZ's Avatar
Updated for sold parts.
Old Sep 26, 2008 | 05:35 AM
FSTASNTZ's Avatar
Prices added below. This SHOULD be all of the remaining parts, but will add to the list as I discover more:
Rear Hub/Spindle/Caliper/Trailing arm conversion 220
Sun Roof Visor 20
Proportioning Valve (ABS) 40
Driver power window motor 40
Passenger power window motor 40
----- Buy the pair of power window motors for 60.00
Driver power mirror 40
Passenger power mirror 40
----- Buy the pair of power mirrors for 60.00
Driver door shell w/ glass & seals 40
Tail light pair 50
Rear hatch with glass and wiper motor 100
Rear finish panel 20
Rear bumper cover assembly 60
Spare 20
Jack, Lug Wrench & Pouch kit 20
Driver's headlight 60
Intermediate shaft 20
Passenger side axle 40
Driver side axle 40
----- Buy both axles and intermediate shaft for 85.00
ABS control unit 40
ABS pump 80
Front ABS sensors 30 each
----- Buy the pair of front ABS sensors for 50
Front right hub/knuckle/spindle 30
Front right fender liner 10
Passenger front fender 70
Hood 120
Front bumper cover 20
Complete wiring harness 240
Sunroof control 20
Trun signal/light controls 20
Hood hinges 10
Washer reservoir w/pump 10
Right front upper control arm 20
Left front upper control arm 20
Shift Knob 40
OEM Radio/CD 60
OEM cup holders 10
Passenger airbag 80
Gauge cluster bezel 20
Driver's exterior door handle 10
Passenger exterior door handle 10
Lock set (trunk, doors, ignition and key) 40
Sun roof glass & assembly 40
Heater core 20
Hood prop 10
Hood latch 20
Hood Latch Cable, 10
Air bag control module and harness 100
GS-R/B18C1 cylinder head, complete from throttle body to head gasket. Assembly has 115,903 miles. Assembly was used on the short block above, head has been verified issue free by THOFF. No distributor included. $440.00 for the assembly.
GS-R OBD2a ECU, from a 1996 GS-R. Car ran perfectly until it was taken apart, $100.00.
GS-R OBD2a Distributor, 100% OEM, not remanufactured, works perfectly, $100.00
GS-R OBD2a injector/engine harness, $100.00
GS-R shift linkage, $80.00
AC compressor 80
PS pump 20
PS reservoir 10
AC Lines 20 each
AC Condensor 60
Radiator (NEW) 100
AC Evaporator 40
PS high pressure line 20
Old Sep 26, 2008 | 07:39 AM
8urcivic's Avatar
Rockin Red Wheels!
8urcivic 8urcivic 8urcivic 8urcivic 8urcivic 8urcivic 8urcivic 8urcivic 8urcivic 8urcivic 8urcivic
price of cluster?
Old Sep 26, 2008 | 07:43 AM
FSTASNTZ's Avatar
Already sold.
Old Sep 26, 2008 | 10:27 AM
c1turbo's Avatar
c1turbo will become famous soon enough
head?
Old Sep 26, 2008 | 10:31 AM
GreatShamanGT's Avatar
GreatShamanGT has disabled reputation
How much for pedals and shifter?
Old Sep 26, 2008 | 10:51 AM
FSTASNTZ's Avatar
Originally Posted by 4drteg
head?
Head is being sold with the long block assembly. Unless you can find someone to split it with you and take the short block.
Old Sep 26, 2008 | 10:53 AM
FSTASNTZ's Avatar
PM sent
