HKS FCD (fuel cut defenser)
I have a brand new never used standard HKS FCD (taken out of box, but I still have the box). I'm asking for $50.
"The HKS FCD is an electronic device developed to properly raise the factory fuel cut level, on factory turbocharged vehicles, to a safe and higher predetermined point. As modifications such as intakes and exhausts are made to optimize engine performance along with utilizing a boost controller to further raise boost levels, the conservative factory fuel cut is often triggered by the higher boost levels which activates a fuel delivery cut off as a failsafe procedure. Symptoms of fuel cut are often expresses as hesitation, bogging, and/or illumination of diagnostic indicators. With the integration of HKS fuel controllers, or in certain cases where the factory fuel curves are very aggressive, an application specific amount of additional boost above factory preset levels can be accommodated. The electronic signal from the FCD will raise the fuel cut level to accommodate for the additional boost without triggering fuel cut and/or an engine diagnostic light. The FCD installation is designed as a simple integration on to the VPC/F-CON or factory ECU harness."
These are the following cars it is guaranteed to work on stated by HKS and the normal listing price for it:
Chrysler Conquest 1983 - 1987 4501-RA002 $150.00
Specs: HKS FCD - Standard - Setting 1
Mazda RX-7 1987 - 1991 4501-RA002 $150.00
Trim: Turbo Specs: HKS FCD - Standard - Setting 1
Mazda RX-7 1993 - 1995 4501-RA002 $150.00
Specs: HKS FCD - Standard - Setting 7
Mitsubishi Starion 1983 - 1987 4501-RA002 $150.00
Subaru WRX 2002 - 2003 4501-RA002 $150.00
Trim: Turbo Specs: HKS FCD - Standard - Setting 10
Toyota Celica 1988 - 1993 4501-RA002 $150.00
Trim: Turbo Specs: HKS FCD - Standard - Setting 7
Toyota MR2 1991 - 1995 4501-RA002 $150.00
Toyota Supra 1993 - 1998 4501-RA002 $150.00
Specs: HKS FCD - Standard - Setting 9
