fully built h22 gt35r
i have decided to try and part out my prelude that i have for sale on the other threads, the motor runs great, and turbo has absolutely no shaft play.
will not sell turbo kit until motor sells
i am not selling any interior parts of the car or exterior/suspension only the motor setup. then i will sell the whole shell.
turbo setup ecu/hondata s200, injectors $1500
MOTOR AND TRANS $3000
entire motor setup trans turbo kit, injectors, hondata, exhaust, innovative race motor mounts and fully built motor for $4000 (motor alone cost me 5000)
engine:396 whp @17psi 296 trq very safe tune
h22a4 sh block darton mid sleeves
acl main bearings
acl rod bearings
stainless oil return line welded to pan
arp head studs
high performance oil pump gear
new vavle seals
mild port polish
arias 88m 9.2-1 pistons
hp turbo rings totalseal
cometic head gasket
crower turbo cams
skunk2 springs titaniium retainers and valves
74mm throttle body and bored out intake manifold
manegement:
hondata s200 p28 ecu
prosport oil pressure gauge
prosport water temp gauge
prosport boost gauge
turbosmart manual boost controller
turbo:
fmax log manifold
gt35r bb turbo 60 trim housing .82A/R exhaust
3in downpipe/ flexpipe and exhaust
hks ssqv blowoff valve
turbosmart 38mm wastegate (open)
3 inch intercooler pipeing cool side 2.5 hot side
custom intercooler 3inches thick 3 onch in/out 12 tall 32 long
acl main bearings
acl rod bearings
arp head studs
new vavle seals
mild port polish
cometic head gasket
crower turbo cams
manegement:
turbo:
fmax log manifold
