FS:Zero Miles Sleeved ITR Motor/Full Race Manny/GT30R
Old Apr 14, 2008 | 08:32 PM
ultravtec757's Avatar
Team Ultraspeed
ultravtec757 ultravtec757 ultravtec757 ultravtec757 ultravtec757 ultravtec757 ultravtec757 ultravtec757 ultravtec757 ultravtec757 ultravtec757
Thumbs up FS:Zero Miles Sleeved ITR Motor/Full Race Manny/GT30R
Engine setup - EVERYTHING for the engine and turbo setup is brand new w/ 0 miles except for the half shaft, axles, and engine and tranny casings. Everything has been inspected and prepped by Abacus and is assembled. I painted the block and tranny casings silver. It just looks like brand new from the factory, nothing crazy. Everyone that has seen it thought I bought a brand new block from the dealership. B18C1 block w/ Golden Eagle sleeves and copper o-rings - 84mm bore, 01 JDM ITR crank (balanced/inspected), Harmonic race balancer/dampner (double-checked and balanced again), Wiseco flat-top turbo pistons (9.2:1 compression/Teflon coated sides), Eagle H-Beam Rods, OEM oil pump, OEM water pump, and OEM timing belt, AEBS head studs, Cometic head gasket, 01 JDM ITR head, 01 JDM ITR cams, BDL bronze cam gears, Ferrea flat faced valves, Import Builders full head valvetrain, BDL bronze fuel rail, Victor X intake manifold port match and mated to a 70mm Edelbrock throttle body, Clutchmaster Stage 3 6-puck sprung clutch, Clutch Specialties 10lb. 2 peice rebuildable flywheel, 00 B16 Tranny w/ Quaife LSD (just found out it needs a new 3rd gear ring gear), 01 JDM ITR injectors, 00 Si harness (mint/uncut), OBD1 VX virgin ecu, ITR valve cover - laser moon cut with matching plastic, Full Race Pro-Am top mount turbo manifold, Garrett GT30R ball-bearing turbo w/crushed aluminum coated exhaust housing inside and outside. The entire long block is fully assembled. The tranny is still apart since it needs a 3rd gear ring gear. $6000.00 takes it all. The turbo and manifold together were $2800.00 by themselves. If someone wants to buy the turbo and manifold together seperately - $2000.00. Motor seperately - $4000.00. Give me a call if you have any questions - 757-635-5000. My name is Ryan and I'm in Greenbrier/Chesapeake.
Old Apr 14, 2008 | 09:13 PM
1ns0mniac's Avatar
we PARTYIN!
1ns0mniac has a reputation beyond repute1ns0mniac has a reputation beyond repute1ns0mniac has a reputation beyond repute1ns0mniac has a reputation beyond repute1ns0mniac has a reputation beyond repute1ns0mniac has a reputation beyond repute1ns0mniac has a reputation beyond repute1ns0mniac has a reputation beyond repute1ns0mniac has a reputation beyond repute
Default Re: FS:Zero Miles Sleeved ITR Motor/Full Race Manny/GT30R
gaaaaaaay.
Old Apr 15, 2008 | 06:33 AM
Team Ultraspeed
You mean yaaaaaaaay!
Old Apr 15, 2008 | 08:15 AM
ant*'s Avatar
HighestTraderRating
Why are you selling? Seems like a lost.
Old Apr 15, 2008 | 01:02 PM
Team Ultraspeed
I'm just going to throw a K20S in it and finish the outside and inside. House projects own me and I don't think I'll have the time or loot to finish the turbo project. Plus the truck is boosted so I'll just have one of each.
Old Apr 15, 2008 | 06:08 PM
flight00's Avatar
flight00 has disabled reputation
yo how much for the bottom end jus block and pistons///
Old Apr 15, 2008 | 06:13 PM
diggity dave's Avatar
VTEC
diggity dave is on a distinguished road
just called u no answer call me 757 329 0472
Old Apr 15, 2008 | 06:44 PM
Team Ultraspeed
Calls and PM's replied to...
Old Apr 16, 2008 | 10:11 AM
Team Ultraspeed
Up
Old Apr 16, 2008 | 11:21 AM
SortaFlush's Avatar
Slammedxpert
Holy shit man. Impressive build, good luck with the sale!
