FS: H22 engines , CP pistons , SA00 helmet , 350lb 7" springs
Old Feb 6, 2008 | 02:02 PM
TNGChris's Avatar
Default FS: H22 engines , CP pistons , SA00 helmet , 350lb 7" springs
this is all from an uncompleted racecar project i bought.
----H22 head parts from the below engine.head casting is junk,most other stuff is good.cams,etc. are all good.
cam caps valve cover,VTEC slenoid sold...tell me what you need.$$
SOLD!!!!-----G-Force open face helmet.SA2000 rated.Large size...great condition,has four track days on it.$75SOLD!!!!
----7" long,2.5" diameter,350lb springs.$20+shipping.
SOLD!!!! ----CP pistons for H22.stock bore.looks like 9:1 compression.some wear on skirts.there's a nick on the edge of one piston,should be easily massaged out.$60:SOLD!!!!
SOLD!!!!----H22A4 short block.stock internals....dropped a valve.head is basically useless.short block has a busted up piston.may be able to overbore the stock sleeves,or may need to be sleeved.perfect for somebody wanting a short block to build up.lower timing belt gear and water pump are gone.
$100 for the short block.PICK-UP ONLY!SOLD!!!!
SOLD!!!!-------H22 JDM short block.stock internals.i do have the windage tray and oil pickup to be included.missing water pipe on back of block.$125:PICK-UP ONLY!SOLD!!!!
Check out my other FS post:Integra swaybars,LCAs,engine mount inserts,auto to manual conversion parts,H/F clutch and flywheel
https://www.vadriven.com/forums/parts-archive-77/fs-civic-integra-swaybars-lcas-helmet-mount-inserts-a2m-conversion-h22-stuff-etc-220486/
All prices do not include shipping.
located in Roanoke,VA.Paypal add 3%.
many vouches if needed.
THANKS
Chris
Old Feb 6, 2008 | 02:03 PM
TNGChris's Avatar
Default Re: FS: H22 engines , CP pistons , SA00 helmet , 350lb 7" springs
up
Old Feb 6, 2008 | 02:04 PM
TNGChris's Avatar
up
Old Feb 6, 2008 | 02:05 PM
TNGChris's Avatar
up
Old Feb 8, 2008 | 03:11 AM
TNGChris's Avatar
still FS!
Old Feb 9, 2008 | 06:22 PM
TNGChris's Avatar
up
Old Feb 10, 2008 | 06:02 PM
TNGChris's Avatar
lower prices.
Chris
Old Feb 14, 2008 | 04:26 AM
TNGChris's Avatar
up
Old Feb 17, 2008 | 04:53 PM
TNGChris's Avatar
still for sale.
Chris
Old Feb 18, 2008 | 07:23 PM
mcspartan1227's Avatar
mcspartan1227 has disabled reputation
any problems with the h22a?
how many miles?
