FS Built sr20det motor swap
Built by millenium racing developement in portsmouth..... i was selloing the car, now i just want to sell the motor.tranny and do an RB swap. heres the info....... swap has about 60,000 miles, 1500 since build
Red top sr20det with built bottom end
Eagle h-beam rods
Wiseco pistons
ARP headstuds
Brand new timing chain assembly
new oil pan
new bearings and seals
cometic headgasket
balanced crankshaft
new battery
new hot and cold side intercooler piping
koyo radiator
hks ssqv b.o.v.
Forge front mount intercooler
Enjuku racing intake
5 speed sr transmission, no grinds
Will throw in a spec stage 3 plus clutch, good for 525 ft./lbs torque.
Asking $3250 since a stock sr20 swap is around $2000-$2500....
Eagle h-beam rods
Wiseco pistons
ARP headstuds
new oil pan
cometic headgasket
balanced crankshaft
new battery
koyo radiator
hks ssqv b.o.v.
dont get me wrong, ive enjoyed the sr20.... but i think for my goals (which have changed since i built the sr20 lol) an rb25det is better for me. orginally when i built the block i was planning for a rather large turbo (gt35r) but now i want something that will be able to make good power without going all out, i.e. stand alone, injectors, turbo.....
so i think my new goal of an rb25det with around 300 h.p. is going to be pretty fun.... thanks for asking though
A RB25 sounds very nice though, haha. Good Luck with the sale.
heres a more in depth breakdown
-red top sr20det with aprx. 50,xxx miles before build, about 2,xxx since build
Built by millenium autosports in portsmouth,VA
all this info is straight from the receipt, i tried to scan it and upload but i wouldnt work... anyone who wants to see the receipt let me know
cometic headgasket $125
timing chain kit $275
oem oil pump $200
wiseco pistons and rings $495
eagle rods $365
oem water pump $75
Engine gasket set $24
valve cover gasket $50
rod bearings $45
main bearings and thrust $80
arp head studs $165
R&R and rebuild $1,750
machine work $300
misc. fluids,bolts,cleaner $45
New head $450
resurface head $50
Replace crank $300
TOTAL $4,852
Other motor parts.......
-enjuku racing intake
-forge front mount
-new battery
-hks ssqv b.o.v.
-replaced all charge pipes
-unknown brand turbo back exhaust
-new koyo radiator and electric fan with samco hoses
oem oil pump $200
eagle rods $365
oem water pump $75
rod bearings $45
arp head studs $165
machine work $300
New head $450
resurface head $50
Replace crank $300
TOTAL $4,852
-forge front mount
-new battery
-hks ssqv b.o.v.
