FS: Aem Injector Driver Box
i have a used aem injector driver box model 30-2710
here's some info taken from aem's website
Peak & Hold Injector Driver Module FAQs...
AEM’s external Peak & Hold Injector Driver module allows ECU’s that have a saturated injector drive circuit to trigger low impedance injectors with a true 4/1 Peak & Hold injector drive circuit.
AEM’s Peak & Hold Injector Driver contains 10 independent injector drive channels. Each channel supplies full battery voltage to a fuel injector for rapid current rise, in order to produce positive injector opening. When load current reaches 4.1A (amps), the injector driver reduces the load current to 1.1A and operates as a constant current source. This condition holds the injector open, and reduces system power dissipation. If the current fails to reach 4.1A within 5mS, the driver module automatically reduces the load current to 1.1A.
Installation is straightforward. Users simply hook the injector trigger wires from an ECU to the module, and then hook the output wires from the module to your injectors. Any number of channels can be used from one to 10.
For high-output engines that have exceeded the capacity of high-impedance injectors
Includes 10 independent injector drive channels for any engine up to V10
Complete wiring system included
Operating Voltage: 8-18 volts, negative ground
RPM Capability: Unlimited
Injector Triggers: 10
Trigger Waveform: Output is activated when input trigger is grounded
Trigger Impedance: 220 Ohm input impedance, pulled to 12V (60 mA draw)
Injector Outputs: 10
Output Current High: 4.15A Peak, Typical
Output Current Low: 1.15A Sustain, Typical
Peak Current Timeout: 5mS
Size: 5.5"L x 4.6"W x 1.4"H
Weight: 2.7 Lbs
Over Temperature Shutdown: 115C (Nominal)
asking $230 shipped
Weight: 2.7 Lbs
asking $230 shipped
Re: FS: Aem Injector Driver Box
someone buy this
someone buy this
bump for new price
RameyBuilt
Engine / Exhaust / Drivetrain
26
03-20-2009 08:16 AM
RameyBuilt
03-03-2009 08:44 AM
