FS:94+ Integra suspension, Aftermarket Gauges,15" steelies
Old Sep 1, 2007 | 10:57 AM
TNGChris's Avatar
Default FS:94+ Integra suspension, Aftermarket Gauges,15" steelies
FS:all of the suspension stuff is off a 95 Integra LS,except the rear swaybar.this car was driven before being taken apart,so everything worked.this stuff has been in storage for a couple months,so i'm assuming it's all still in good shape as far as calipers,etc.
-front 10.3" brake conversion.complete spindle/rotor/hub/caliper assemblies.brake lines are cut.rotors slightly rusty,probably useable.
$100
-front LS 22mm swaybar.includes bar and D-bushings only.i have ONE of the front LCAs with swaybar mounts,the driver side.
$30 for the bar,$15 for the LCA
-rear disc conversion.complete trailing arm/toe link/hub/rotor/caliper/LCA/cable setup. brake hoses and cables are cut,but i do have an uncut set of E-brake cables to include.driver side LCA is missing the inner sleeve on the shock bushing.i can also remove the hub assemblies from the trailing arms to cut donw on shipping cost/size.rotors slightly rusty,probably useable.
$100
-rear GSR swaybar.complete,including bar/endlinks,D-bushings and brackets/mounting brackets/endlink to LCA bolts.all you need to bolt this onto a non-swaybar car is LCAs and four bolts to attach the mounting plates to the subframe.
$50
-2-1/16" Faze boost gauge.lights up,i used a vacuum pump to demonstrate vacuum and boost.
$20
-2-1/16" Autometer Phantom mechanical oil pressure gauge,0-150psi.lights up,i was able to verify 15psi with my crappy pump on it.red bulb "condom",can be removed to make light white.dirty,just needs to be cleaned up.
$20
-2-1/16" Autometer Sport Comp A/F gauge.
$25
-Hyundai OEM steelies.
15"x6"
4x114.3mm
+46mm offset
$40
all prices are plus shipping,from Roanoke,VA 24012.i can give shipping quotes,just give me your zip and what items you want.prices are negotiable.plenty of references if needed.
THANKS
Chris
TNGChris's Avatar
Default Re: FS:94+ Integra suspension, Aftermarket Gauges,15" steelies
Old Sep 2, 2007 | 07:18 PM
TNGChris's Avatar
forgot to mention-i'll take $275 for the whole suspension setup.
Chris
Old Sep 4, 2007 | 01:52 PM
TNGChris's Avatar
prices lowered,edited above.
Thanks
Chris
Old Sep 8, 2007 | 12:29 PM
TNGChris's Avatar
prices lowered again.
Thanks
Chris
Old Sep 12, 2007 | 04:28 PM
TNGChris's Avatar
still got all this stuff,make offers!
Thanks
Chris
Old Sep 26, 2007 | 01:53 PM
TNGChris's Avatar
gauges and swaybars on Ebay now:
http://motors.search.ebay.com/_W0QQsassZteamnextgen
Thanks
Chris
Old Oct 1, 2007 | 06:10 PM
TNGChris's Avatar
one day left!still great prices!
Thanks
Chris
domesticimport
Wheels / Tires
Jan 18, 2009 04:22 PM
tatmonster
Want to Buy / Trade ARCHIVE
Sep 30, 2008 02:44 PM
lionman197924
Oct 4, 2007 06:47 PM
