Few parts for sale(will be continually updated)
Ohhh Snap
D16z6 head unknown miles but valves seat great and dont leak,has a y8 cam gear cause it was on a y8 bottom end.Non vtec valve cover and a mint vtec solenoid.--------sold
obd1 p05 ecu chipped and converted to vtec,7800 redline,4400 two step,secondary o2 removed,and on a p28 base map------------sold
new remanufactured(about 10 miles of it i put on----obd1 dizzy-a must have to run a d16y8 vtec in a obd1 chassis,or for a stock obd1 non vtec motor--------sold
obd0 pm6 and pr4-either one for 30 obo,virgins and mint.
b series into ef rear tranny bracket-20
b series into ef power steeing pump and bracket-30
d series into eg rear tranny bracket-15
d series into ef rear tranny bracket-15
D16y8 dizzy converted to obd1 plugs(this is so you can run a d16y8 vtec head in a eg civic)-----sold
blue ngk spark plug wires for 92-99 sohc vtec-------sold
stock obd1 d series header with 02 sensor-20
obd0 stock ls header-15
d16z6 hyrdo tranny, tranny should be mint,but the large bolt on the side of it cross thread and cracked the casing,so it needs a new case----------sold
blue short throw shifter-20
jdm d15b vtec head,no vtec solenoid and has 2 bent valves and missing the cam and cam gear-30 as is,150 all new valves and valve stem seals and resurfaced.-------------sold
I have a couple d series starters-15 each
stock 89-91 crx rear lca's-10
honda resistor box and plug-10
stock eg outter tail lights-20 both
stock ls oil pan,with drain bolt-20
d series power steering pump-15
Stanley dual flood lights with stand-new bulbs-30
red 8 or 9 mm b16 spark plug wires-20
Blitz dual turbo timer.-80 basic install(enough to do its job but not air fuels or boost hooked up-that would be a little more for full install)
i will have more once i look around but thats a jist of it.
Ohhh Snap
Re: Few parts for sale(will be continually updated)
upppppppp best offer peoplessss
Chirp Chirp.....
so can i use this dizzy?
Ohhh Snap
Chirp Chirp.....
pm me if u have that dizzy....(round plugs) i need it
Ohhh Snap
y8 dizzy sold.
Ohhh Snap
turbo timer uppppp
Ohhh Snap
uppppp
Ohhh Snap
heylow
Ohhh Snap
upppp
