F/S ALPINE CVA-1006
I have a Alpine CVA-1006 for sale. Retails for $1200 new. Im trying to get $600 for it. NO TRADES!!! CASH ONLY!!!
Features: Ai-Net Ai-Talk Display External Processor Audio Full Control External Processor Preset Function Recall M.I.X. ALL Multi CD Shuttle Control CD Shuttle Control Direct Disc Selection Disc Play/Pause Disc Title Memory Elapsed Time Display Forward/Backward M.I.X. (Random Play) Music Scan Music Sensor Up/Down Repeat T.S.M. (Title Search Menu) General-Head Units "Digital-Art"Spectrum Analyzer 3 PreOuts 4 V PreOut 45W x 4 High Power Amplifier CD Shuttle Control Function Clock Demo Function Dimmer-on Lead Dual-In Gold-Plated RCA Connectors Loudness Operation Indicator Power Antenna Lead Preamp Fader Rotary Encoder Volume Knob S.T.M.(Source Tone Memory) Selectable Fader Separate Bass & Treble Control Sound Guide Subwoofer Level Control Tone Bypass Wireless Remote Control Included Tuner Auto Memory D.A.P. (Direct Access Preset) FM Station Indicator High Speed Tune Local/DX Selection MaxTune SQ Tuner Mono Switch Preset Stations (FM:12/AM:6/DAP:6) Signal Level Indicator Station Title Memory Title Search Menu Travel Search Up/Down Seek Specs: AM Tuner Tuning Range : 530-1, 710kHz Usable Sensitivity (IEC Standard) : 22.5/27.0 (µV/dBf) FM Tuner 50dB Quieting Sensitivity : 13.5 dBf(1.3µV/75 ohms) Alternate Channel Selectivity : 80.0 dB Capture Ratio : 2.0 dB Mono Usable Sensitivity : 9.3dBf (0.8µV/75 ohms) Signal-to-Noise (S/N) : 80.0 dB Stereo Separation : 35.0 dB Tuning Range : 87.7-107.9MHz General-Head Units Bass Control Range at 60Hz : ±15 dB Continous Power Output (Note 2) : 19W x 4 Loudness Control at 100Hz (Max) : +10dB Maximum Mounting Angle : 30° from Horizontal Maximum Power Output (Note 1) : 45W x 4 Monitor Chassis Size : (W x H x D) 178mm x 50mm x 156mm Operating Temperature (°C/°F) : +32°F to 113°F (0°C to + 45°C) Power Requirement : 14.4(11-16) V.DC Pre Output Voltage (Before Clipping) : 2V Treble Control Range at 10kHz : ±10 dB Tuner Section Size : (W x H x D) 259mm x 437mm x 177.5mm Weight (Monitor Section) : 1.7kg (3lbs. 12 oz) Weight (Tuner Section) : 1.6kg (3lbs. 8 oz) Monitor Illumination System : U-shaped cold cathode fluorescent tube LCD Type : Transparent TN LCD Number of Picture Elements : 336,960 pcs. (1,440 x 234) Operation System : TFT Active Matrix Screen Size : 6.5" (Diagonal) PM me to meet up. My name is Cody and I am located in Chantilly. |
