F/S ALPINE CVA-1006
F/S ALPINE CVA-1006
I have a Alpine CVA-1006 for sale. Retails for $1200 new. Im trying to get $600 for it. NO TRADES!!! CASH ONLY!!!
Features:
Ai-Net
Ai-Talk Display
External Processor Audio Full Control
External Processor Preset Function Recall
M.I.X. ALL
Multi CD Shuttle Control
CD Shuttle Control
Direct Disc Selection
Disc Play/Pause
Disc Title Memory
Elapsed Time Display
Forward/Backward
M.I.X. (Random Play)
Music Scan
Music Sensor Up/Down
Repeat
T.S.M. (Title Search Menu)
General-Head Units
"Digital-Art"Spectrum Analyzer
3 PreOuts
4 V PreOut
45W x 4 High Power Amplifier
CD Shuttle Control Function
Clock
Demo Function
Dimmer-on Lead
Dual-In
Gold-Plated RCA Connectors
Loudness
Operation Indicator
Power Antenna Lead
Preamp Fader
Rotary Encoder Volume Knob
S.T.M.(Source Tone Memory)
Selectable Fader
Separate Bass & Treble Control
Sound Guide
Subwoofer Level Control
Tone Bypass
Wireless Remote Control Included
Tuner
Auto Memory
D.A.P. (Direct Access Preset)
FM Station Indicator
High Speed Tune
Local/DX Selection
MaxTune SQ Tuner
Mono Switch
Preset Stations (FM:12/AM:6/DAP:6)
Signal Level Indicator
Station Title Memory
Title Search Menu
Travel Search
Up/Down Seek
Specs:
AM Tuner
Tuning Range : 530-1, 710kHz
Usable Sensitivity (IEC Standard) : 22.5/27.0 (µV/dBf)
FM Tuner
50dB Quieting Sensitivity : 13.5 dBf(1.3µV/75 ohms)
Alternate Channel Selectivity : 80.0 dB
Capture Ratio : 2.0 dB
Mono Usable Sensitivity : 9.3dBf (0.8µV/75 ohms)
Signal-to-Noise (S/N) : 80.0 dB
Stereo Separation : 35.0 dB
Tuning Range : 87.7-107.9MHz
General-Head Units
Bass Control Range at 60Hz : ±15 dB
Continous Power Output (Note 2) : 19W x 4
Loudness Control at 100Hz (Max) : +10dB
Maximum Mounting Angle : 30° from Horizontal
Maximum Power Output (Note 1) : 45W x 4
Monitor Chassis Size : (W x H x D) 178mm x 50mm x 156mm
Operating Temperature (°C/°F) : +32°F to 113°F (0°C to + 45°C)
Power Requirement : 14.4(11-16) V.DC
Pre Output Voltage (Before Clipping) : 2V
Treble Control Range at 10kHz : ±10 dB
Tuner Section Size : (W x H x D) 259mm x 437mm x 177.5mm
Weight (Monitor Section) : 1.7kg (3lbs. 12 oz)
Weight (Tuner Section) : 1.6kg (3lbs. 8 oz)
Monitor
Illumination System : U-shaped cold cathode fluorescent tube
LCD Type : Transparent TN LCD
Number of Picture Elements : 336,960 pcs. (1,440 x 234)
Operation System : TFT Active Matrix
Screen Size : 6.5" (Diagonal)
PM me to meet up. My name is Cody and I am located in Chantilly.
Features:
Ai-Net
Ai-Talk Display
M.I.X. ALL
CD Shuttle Control
Disc Play/Pause
Disc Title Memory
Forward/Backward
Music Scan
Repeat
General-Head Units
3 PreOuts
4 V PreOut
Clock
Demo Function
Dimmer-on Lead
Dual-In
Loudness
Operation Indicator
Power Antenna Lead
Preamp Fader
Selectable Fader
Sound Guide
Tone Bypass
Tuner
Auto Memory
High Speed Tune
Local/DX Selection
MaxTune SQ Tuner
Mono Switch
Title Search Menu
Travel Search
Up/Down Seek
Specs:
AM Tuner
FM Tuner
General-Head Units
Monitor
