COMPLETE H2B SWAP. lots of aftermarket and extras. PLUS ADDITIONAL B-SERIES SWAP PART
I have forsale in nova:
Will take a civic VX engine parts for trade(vx longblock, cx or vx tranny). Need an entire VX swap with axles, mounts, wiring harness, ecu. Also need an additional VX head.
Would also take an SI EF hatch!!!!!!!!!!
I have an H2B swap to offer that would make a very awesome street engine, or a really great track performer as well.
here we go:
EVERYTHING BELOW FOR $5000 OBO
BRAND NEW EVOLUTION industries, Bisimoto Signature Series (lighter, $1300) H to B adapter plate kit
Transmission Adapter Plate with Dowels
One Piece Flywheel
Polished Billet Motor Mounts with A70 Urethane Inserts
CNC Machined Drivers Side Engine Mount
Extended Shift Fork
Clutch Slave Cylinder Adapter
Intermediate Shaft Adapter
All Necessary Hardware
Complete Instructions
Template for Block Notching
PCV Adapter, to Clear Hood Better
-Socketed and setup for data logging P28 ECU(has notch in ecu cover for fast chip changes as well as a speed socket)
-Stock 4 wire O2 sensor
-(4) ACCEL 36 lb/hr injectors (380 cc/min) New in box. High Impedance injectors.
-ITR tranny w/LSD of course. Most trannys dont come with half the things i have listed.
-this is the bar code and lsd code
s80-3091463
lsd n3e
-mileage is roughly 50,000
-the tranny is in good working condition
-bseries shift linkage
-axles (boots are ripped, so theyll need replacing-cost 10$)
-starter
-upper tranny mount
-flywheel cover
-all hardware
-A complete ready-to-go transmission.
-(1997' head code) H22A1 longblock
Most longblocks dont come with half of the hardware/mounts miscelaneous items i have, which is all taken into account in my price
-Rocket motorsports valvesprings/retainers (new in box, worth $300)
-Handmade tig welded $550 custom prototype H22 4-2-1 header with 2.5" collector, made for mild to medium cams
-DC sports 4-2-1 ceramic coated header in really good condition, worth $150
-brand new phenolic thermal intake gasket, worth $50
-no intake manifold
-engine wiring harness
-H22 starter
-H22 alternator
-H22 distributor and wires with good cap and rotor
-all engine/tranny mounts
-intake manifold bracket, bolts, accesories, and sensors
-halfshaft
-timing belt plastic covers
-everything between the valve cover and oil pan
-engine has about 80,000 miles on it and was pulled from a well running car. -engine has not been taken apart.
-BRAND NEW H22 JDM-type S OVERSIZED pistons/rings/pins, in the Honda boxes. only removed from box to look.
$5 each: 2 Honda OEM oil caps
EVERYTHING ABOVE FOR $5000 OBO
OTHER
$65 drivers' side upper integra motor mount (silver one) AND rear engine mount
$15 each: Pr3 and P30 AC brackets
$75 B-series crank pulley, bolt and key. I will also turn off the outer pulley for an additional 50$
$15 Bvtec intake/exhaust valve seals and cam seals. New in packaging. Felpro
$7 shipped New in wrapper OEM RSX oil filter. Used on Bseries to increase oil pressure
$30 bare(no sensors) GSR intake manifold
here we go:
One Piece Flywheel
Extended Shift Fork
s80-3091463
lsd n3e
-starter
-upper tranny mount
-flywheel cover
-all hardware
-no intake manifold
-H22 starter
-H22 alternator
-halfshaft
OTHER
