CLEANING OUT THE GARAGE: ALOT OF D AND B SERIES PARTS
Old Jul 31, 2008 | 02:51 PM
widebody91hatch's Avatar
widebody91hatch has disabled reputation
Default CLEANING OUT THE GARAGE: ALOT OF D AND B SERIES PARTS
PAT
NORFOLK
PM ME OR CALL ME AT 757 202 0386
ALL PRICES ARE NEGOTIABLE BUT I'M NOT GIVING THEM AWAY
WILL TRADE FOR CRX SI CARPET(BLACK ONLY), DC INTEGRA FRONT END PARTS, DC LHD DASH, GSR BLACK CLOTH SEATS OR B SERIES SWAP PARTS
PM ME FOR PICS
-COMPLETE Y8 INTAKE MANIFOLD W/ ALL SENSORS,TB, FUEL RAIL AND INJECTORS- $80
-Y8 OIL PAN- $30
-Y8 WATER OUTLET PIPE W/THERMOSTAT HOUSING- $30
-Y8 TIMING BELT COVERS(UPPER AND LOWER)- $10
-Y8 TIMING BELT SIDE MOTOR MOUNT BRACKET-$10
-Y8 CRANK SENSOR-$10
-Y8 ALTERNATOR- $50
-STOCK D SERIES CLUTCH WITH PLENTY OF MEAT LEFT- $40
-STOCK D SERIES FLYWHEEL(NEEDS TO BE RESURFACED)- $40
-Y8 CRANKSHAFT(NEEDS TO BE MACHINED-DAMAGED ON #4)- $30
-DA A/C COMPRESSOR (R12)- $30
-3 PR3 PISTONS AND CONNECTING RODS- $25 EACH OR $60 FOR ALL
-B16A CRANKSHAFT(NEEDS TO BE CHECKED-NO APPARENT DAMAGE)- $50
-2 STEELIES WITH GOOD TIRES- $30 EACH (THEY ARE 185/65R14)
-1 STEEL WITH A MESSED UP TIRE- $10
-B SERIES? REAR MOTOR/TRANS MOUNT(WON'T FIT GSR-SO I'M NOT SURE)- $20
-VARIOUS B AND D SERIES BRACKETS(ALT AND PS)
-EF BLACK DUAL HALO PROJECTOR HEADLIGHTS - $100 FOR BOTH WITH ALL THE WIRING
-EF OEM HEADLIGHTS- $50
-UNKNOWN LARGE WASTEGATE- WAS TOLD ITS A TIAL KNOCKOFF BUT I'M NOT SURE - $50
-95-97 VW PASSAT CLUSTER - $50
-EF 4 DOOR PASSENGER CORNER MARKER - $15
-B18B DISTRIBUTOR CAP(NEW) - $5
-98 DODGE DAKOTA STOCK FOG LIGHT LENSES - $40 for the pair
-98 EXPLORER PASSENGER INNER TIE ROD(NEW) - $ 20
-H22 CAM SEALS(x2)(NEW) - $10(FOR BOTH)
-H22 CRANK SEAL(NEW) - $10
-D16 INTAKE MANIFOLD GASKET(NEW) - $5
-D16 EXHAUST MANIFOLD GASKET(NEW) - $10
-B16A CRANKSHAFT PULLEY WITH BOLT AND PIN- $20
-VARIOUS B SERIES INTAKE AND EXHAUST GASKETS(B16,B18B,B18C, ETC) - $10 EACH
-B16A TIMING BELT BNIB - $25
-1988 TO 2000 OLD BODY GM TRUCK AND SUV POWER WINDOW MASTER SWITCH FOR 4 DOOR(CAME OUT OF 98 ESCALADE)WOOD GRAIN COLOR- $80
-88 CRX SI DASH (BLACK WITH GRAY TOP-ONE CRACK BUT ITS NOT BAD AT ALL)- $80
-EF SI INSTRUMENT CLUSTER W/ 64K- $50
-D SERIES CABLE TRANNY W/ NO PROBLEMS- $200
WILL ADD PARTS AS MORE COME FOR SALE
Old Aug 1, 2008 | 04:08 PM
Default Re: CLEANING OUT THE GARAGE: ALOT OF D AND B SERIES PARTS
Old Aug 2, 2008 | 02:26 AM
Old Aug 2, 2008 | 02:41 AM
8urcivic's Avatar
Rockin Red Wheels!
8urcivic 8urcivic 8urcivic 8urcivic 8urcivic 8urcivic 8urcivic 8urcivic 8urcivic 8urcivic 8urcivic
are all of your parts that are new....as in your gaskets and seals.....are they oem honda or advanced brand?
not bashing just asking.
an oem b16 tbelt bnib from honda.....amazing deal......if thats the case.
Old Aug 2, 2008 | 12:32 PM
no they are not oem honda seals/gaskets if they were i would have listed them as oem.... they are from bap geon and they are brand new never used i just don't need them... and no the timing belt is not honda oem it is actually a duralast from autozone... i bought it and never used it i could take it back but i figured somebody might be able to use it
Old Aug 2, 2008 | 01:20 PM
Old Aug 3, 2008 | 08:22 AM
Old Aug 4, 2008 | 03:29 PM
Old Aug 5, 2008 | 06:08 PM
Old Aug 6, 2008 | 02:32 PM
BUMP
