BAD ASS honda parts. EK part out.
All stuff is B series.
97 EK hatch w/ 00 front end conversion w ctr lights. Has a 6 point roll cage but can be removed if needed. includes SI gauge cluster, stock B series mounts, walbro 255. also has all the solid bushings in the front end and extended wheel studs.It has a carbon hood (needs re clearing) duck bill and front lip. and a momo steering wheel oh yea its wire tucked and comes w/ skunk2 drag coilovers. $3000
IM NOT SELLING THE GAUGE CLUSTER by itself
complete LS Vtec long block (valve cover to oil pan ready to run) $2900
motor has 20 passes on it. itd cost 6k to build from scratch.
B16 head race ported w crower springs and retainers $850
880cc seimens injectors w/ resistor pack $175
Crower stg2 turbo cams $300
B18 block w/ eagle rods wiesco pistons 9:1 w/ 20 quarter mile passes still running right now. includes everything from the deck to the pan. even throw in the oil lines for turbo and vtec head. $1600
ACT 6 puck clutch w/ race flywheel $200
corbeau race seat non adjustable $120
MSD 6AL w 3 step module $250
turbonetics stg5 60-1 (good for 550whp) $500
Custom tubular race turbo manifold and 4in down pipe $650
Tial 44mm wastegate $175
HUGE front mount intercooler $450
CROME chipped ecu w conversion harness for obd2a $300
obd2 distributor w MSD cap and coil $225
B series shift linkage w solid bushings $150
ATI harmonic balancer pulley $225
4in mandrel exhaust for EK $300
MSD blaster coil and cap $30
any questions pm or call 757 339 6495 scott
the car is still completely together w all this stuff and is for sale as a whole. it make 465whp w these parts. I jus want a new project. also location is portsmouth at MRD formally millennium autosports
Re: BAD ASS honda parts. EK part out.
6 puck and flywheel....how many miles on clutch...how many lbs is the flywheel....ill cop that asap...
Hardly working
what color is the str throttle body very intrested. TPS come with?
The throttle body is polished aluminum and comes w/ tps. The clutch has some decent miles on it but its holding 450whp so id say its good and the flywheel is 10lb i think.
you parting anything out from the car itself??? like headlights or cage??
Hardly working
yea i want to get the throttle body off u then. When can i pick it up?
Moderator
pics of seaT? I want the B+M fuel pressure regulator and gauge
il get pics up asap. the throttle body should be sold. come get the regulator and gauge
