Aem FIC BNIB
Old Nov 22, 2008 | 06:47 PM
cheesebox's Avatar
cheesebox has disabled reputation
Default Aem FIC BNIB
This is a brand new Aem Fic, I have a post in my local forum but I am willing to offer this for 350$ shipped 330$ picked up in herndon va. Or trades are accepted!
Old Nov 23, 2008 | 08:15 PM
cheesebox's Avatar
Default Re: Aem FIC BNIB
OVERVIEW OF THE AEM FUEL / IGNITION CONTROLLER (F/IC AEM Fuel / Ignition Controller 30-1910 at Tuner Tools, the Inside Line
The F/IC gives users with OBD-II vehicles and non-factory forced induction systems the ability to retard ignition and deliver accurate amounts of fuel without the need for outdated FMUs or “boost hiding” controllers. This system works parallel to the factory ECU preventing tuning limitations due to complex factory timing patterns and will not cause a check engine light (CEL).
KEY FEATURES of the AEM 30-1910 Fuel / Ignition Controller
The AEM F/IC works with latest OBD-II vehicles including variable valve control
VTEC controller based on Engine RPM and Load
Six (6) injector inputs with simulated injector load used when remapping OEM injectors
Six (6) fuel injector controllers for either remapping of ECU output (+/- 100% trim) or as a stand-alone extra injector driver
21x17 maps with configurable load and RPM breakpoints
Analog in / out for remapping / clamping MAF
F/IC draws power from PC USB interface for quick and easy calibration changes
64kb on-board data logger
Drives high impedance injectors or low impedance injectors with use of Peak & Hold Injector Driver Box
Three (3) channels of timing retard
The AEM 30-1910 supports MAG or HALL sensor types
On board 41PSIA (approx. 25PSI boost) manifold pressure sensor
The AEM 30-1910 is programmable with included Windows-based Tuning Software
http://tunertools.com/proddetail.asp?prod=AEM-30-1910
Old Nov 27, 2008 | 11:34 AM
cheesebox's Avatar
330$ I know someone wants this. I need racing seats, fixed back with a sub-hole. FIA certified preffered. Or I need a roll-cage fabricated.
calisol
Engine / Exhaust / Drivetrain
21
Feb 6, 2009 03:19 AM
C_WAKE
Nov 3, 2008 01:42 PM
96gsr
Jul 3, 2008 05:44 AM
oduhockey9
Feb 4, 2008 07:55 PM
