440cc injectors for hondas
theboytheycallsam
440cc saturated injectors for hondas. They plug right up. $60 bucks obo
Team Ultraspeed
Re: 440cc injectors for hondas
I do not need a set, but it may help to let people know whether they are OBD0 peak & hold (low impedance and needs a resistor box) or saturated (high impedance and does not need a resistor box)
What will they work on I need some for my 99 gsr motor
theboytheycallsam
it will plug right up
Team Ultraspeed
plug up to what? You know, there ARE different injector plugs for Hondas.
hey man i need to kno if their saturated or peak and hold if their saturated i need em' asap and wat r they 4?
theboytheycallsam
they were on a turbo 95 ls motor.
Team Ultraspeed
Do you run a resistor box for your injectors? If you did, It would be a silver box with cooling fins on top located in the upper driver's side of the engine bay right next to the clutch master cylinder and reservior.
theboytheycallsam
naw I didnt.
Team Ultraspeed
There you go...you're running a set of high impedance injectors or better known as saturated injectors. You may want to update your thread to state such. It may be easier to sell them and get less comments such as mine.
gl
gl
