MY s13 Sr20det track car part out... i need a HOUSE YO. LOTSSS OF PARTS!!!!!!!!!!!!!!
Means of contact: 919 995 5453, pm , or srkoukimonsta@gmail.com
Price: $look
Description:
Well i found a deal on this house in my neighborhood and id rather have it than this roll caged car. the shell will be for sale but is currantly awaiting one headlight cover to be painted.
I am going to try and make this as organized as possible. everything is for s13 unless stated otherwise. all prices are picked up. shipping will be a little extra.
I GURANTEE ALL MY PARTS WORK OR YOUR MONEY BACK
Willing to do packaged deals
SUSPENSION PARTS
D2 coilovers great shape on my DD sr s13 now. i love them - 600
almost new Tanabe sustec pro SS coilovers with brand new tein upper front camber plates-680
NEW Megan racing rucas-110
NEW Megan racing toe rods-90
NEW Megan Racing Tension rods-90
NEW Megan Racing Tractoin rods-60
NEW megan subframe collars- 60
NEW Suspension technique Front and Rear sway bars-180
White line adjustable front and rear Sway bars.-200
NEW Megan Racing inner hard tie rod and outer adjustable tie rod end- 120
NEW Nismo power brace- 120
lightl used KYB shocks with Eibach springs. nice drop- 300
HUBS/Brakes
Ichiba 5 lug conversion for s13. Fronts are brand new, rears are slightly used but are still in great shape. -320
Remanufactured Z32 Front calipers with new Hawk pads, New fittings and New conversion lines- 150
Remanufactured Z32 Rear Calipers with new hawk pads, New fittings, and New lines- 120
New Brembo Blank Rotors to go along with this setup-120 for all 4 or 60 for each pair.
Z32 dif tokico BMC- 140
NEW Ksport Hydraulic ebrake with NEW jegs prop valve and all the NEW brake lines you need. already installed on the car wroking great!!- 160
Interior-
F1 spec type 3 seats- 380
Mint uncracked black dashes.. i have 3- 70 a piece
Silvia cluster, i have 2- 60 a piece
dohc clusters- 35 a piece
Climate controls- 20 a piece
i also have a alot of the plastics and switches and such, just contact me
Engine Swaps
I have 2 engine swaps for sale.. these are complete swaps that have been wired up for 240sx and run great.
Stock Sr20det swap. Ran in one of my cars flawlessly. that car. i parted the car out and was going to use this for my caged car- 1500 for the full swap. comes with modded harness so its all plug and play. Tranny is great. zero issues. swap has aftermarket divorced outlet
Semi restored SR- SR with new water pump, New exhuast mani stud kit, New oil pick up, New oil pan, New Megan Racing exhast mani, New Megan racing turbo elbow, New SS turbo lines, and an ACT clutch.
i am looking to get 1900 for the swap with everything or i can give you stock manifold, lines, and elbow to make it cheap.
WILL GET pics upon request.
After market engine parts
NEW HDI GT2 FMIC.. retail is 650 plus shipping if you can find them. these put the GTs to shame- 400!!!
New Turbo smart dual port BOV with hit pipe and seperate extra flange- 160
Lightly used HKS ssqv ver 2 with recirc nose cone on SR hot pipe- 170
Almost new Apexi GT front mount core- 250
NEW Koyo radiator for s13 with sr... can work on s14 with sr. - 220
New permacool electric 14 inch fan- 80
New C/S over flow tank- 50
used permacool electric 14 inch fan- 60.... i think you can fit both of them on any schassis radiator.
NEW ACT 6 puck clutch. 0 miles.. for SR- 250 dollars
exedy flywheel- 220
Turbo xs rfl bov on pipe- 100 dollars
NEW Project silvia engine mounts with NEW nismo tranny mount- 90
i have a couple S13 3 inch no name catbacks. contact me if you are interested
NEW nismo SS Clutch line- 70
Ebay fmic kit, comes with everything you need- 140
Walboro 255 lph
Drivetrain.
lightly used Aluminum 1 piece driveshaft for s13. - 260
B&M Short shifter- 120
j30 vlsd, super clean- 160
5 speed s13 drive shaft- 50 a piece
clutch pedals with clutch master- 60
s13 manual speed sensors- 35
Clutch hard lines- 20
5 speed brake pedal with BMC- 40
STOCK SR parts
Stock complete head- 250
Oem replacement head gasket new in package- 40
Stock Crank in perfect shape- 80
stock bare block- 100
stock complete sr block with water pump... no flywheel- 300
Stock bare head thats been resurfaced and cleaned- 100
Stock starters- 70
Stock altenators- 50
Stock coil packs- 60 for a full set or 20 a piece
Stock mafs- 50
Stock sr rubber intake pipes- 15
Stock Ignitor chips- 50
Stock TPS- 20
Stock throttle body- 20
Stock iacv- 20
Stock SR tranny- 160
stock lower 5 speed harness- 40
Stock SR ecu redtop- 100
Modded SR redtop harness. super clean works fine- 170
Stock CAS- 65
Exterior
Orignt replica front body kit for pop ups s13. has a crack on the lip area but can easily be fixed. amazing fitment- 70
Mint origin replica rear bumper with amazing fitment- 80
silvia Qs front bumper- 40
Spoilerless, wiperless, s13 hatch with glass still- 50
Wheels
MB Atech Battles- 5x114.3 17x8 +28 and 17x9 +17. Front wheels are used and rears are new. BRAND NEW SUMITOMO HTR A/S P01 tires. total cost for this setup is over 1100. i just want to get 680 for them .
SSR hasmi sport wheels.- 17x9 +22 all around. come with tires, fronts are good and rears are bald- 600
Enkei EV5 wheels with tires.- 17x7 +32 offset- 450
Senta SER wheels with tires- 220
Im sure i left a few things out that ill add to the list. from now on this will be my for sale list
PICS
pics will be up in a few minutes
atech wheels
one wheel has a few scuffs. nooo curb rash though
pics of each wheel
Pic of tires
z32 bmc
k sport hydraulic hand brake-
HDI fmic gt2 kit-
ICHIBA hubs-
nismo power brace-
SSR wheels
Brake setup...
new ss brake lines
Tanabe sustec pro SS coilovers with tein camber plates
aluminum 1 piece drive shaft
megan racing suspension parts
Price: $look
Description:
SUSPENSION PARTS
HUBS/Brakes
Interior-
Engine Swaps
exedy flywheel- 220
Walboro 255 lph
Drivetrain.
STOCK SR parts
Stock starters- 70
Stock mafs- 50
Stock TPS- 20
Stock iacv- 20
Stock CAS- 65
Exterior
Wheels
PICS
atech wheels
pics of each wheel
Pic of tires
z32 bmc
HDI fmic gt2 kit-
ICHIBA hubs-
nismo power brace-
SSR wheels
Brake setup...
new ss brake lines
Re: MY s13 Sr20det track car part out... i need a HOUSE YO. LOTSSS OF PARTS!!!!!!!!!!
would you ship?
You Sir have a PM
Sent you an Email about the engine and tranny mount!
Friendly Jackboot
pm'd you i need the upper portion of the driveshaft and the shifter assembly as long as it works.
tension rods & body kit still available? if so text 757-354-9702
Still have the brakes?
still have driveshaft and nismo power brace?
how much for all the megan parts
where are you located do you still have all the megans arms and stuff how much for all of them let me know thanks.. napL3X@gmail.com
