94 Integra RS/GSR shell and parts partout S2,Arp,Acl,OE
Means of contact: pm message or post on thread. cell phone is broken
(8048944577) Not all pictures are on here as you can only attatch 10 if you need other pics let me know and i will text them to you.
This was my fiances car for 2 years, the piston ring went and now we are looking at new cars, need the money for downpayment. So NO I WILL NOT TAKE TRADES and dont try to lowball me i know what i have! any shit comments can be kept to yourself... There are alot of new parts as well as used engine internals and other stuff, basically a whole car minus a transmission. I also WILL NOT PART OUT THE SHELL it comes complete as it sits.
94 Integra RS model wired for vtec 20% window tint and Very clean interior 9.5 out of 10 the only interior issue is the sun fading on the tops of the rear seats. Needs some body work but not bad for a 17 year old car. has a jdm type r gauge cluster and rear camber kits. the dc header and apexi 2.5" piping comes on the car. $1400 FIRM
1997 usdm GSR cylinder head complete with caps, cams and valve cover $425
1997 usdm B18c1 bottom end complete but needs piston rings (have in this sale also) $450
engine had around 160k before removing from the car
Skunk 2 Pro series intake manifold + 72mm throttle body (on car for 12k) w/rail and injectors and sensors $425
td-68u Gsr distributor almost new $200
Gsr thick radiator low miles w/fans $160
Engine Gasket rebuild set for B18c gsr and typr r $60
OEM honda vtec solenoid gasket (new) $15
OEM usdm type R oil pump (new) $100
Acl B18c standard size Race Main and rod bearings w/ trust washers $110
NPR standard size b18c piston rings $35
ARP Headstuds (new in box) for b18c gsr head only $135
Used working a/c compressor (dirty from p/s pump leak) $75
Apexi World sport 1 muffler $130
[ATTACH=CONFIG]126798[/ATTACH][ATTACH=CONFIG]126799[/ATTACH][ATTACH=CONFIG]126797[/ATTACH][ATTACH=CONFIG]126796[/ATTACH][ATTACH=CONFIG]126795[/ATTACH][ATTACH=CONFIG]126794[/ATTACH]
[ATTACH=CONFIG]126800[/ATTACH][ATTACH=CONFIG]126801[/ATTACH][ATTACH=CONFIG]126802[/ATTACH][ATTACH=CONFIG]126803[/ATTACH]
Re: 94 Integra RS/GSR shell and parts partout S2,Arp,Acl,OE
DUKE BLUE DEVILS
Any pics of the muffler? Will it fit a 4dr?
How much for the interior less the seats and ill come and pull it and price on door harness both. call if you want 804-337-3863 thanks chris
Again DO NOT ASK for me to Part out the SHELL It comes COMPLETE for the person who wants a Drop in a motor and go car. IT IS IN THE Description, Will not part with the interior or anything thats still attatched to the car.
1FastSS/SC
08-01-2009 12:35 PM
