R/C car parts
Everything is brand new and in the original packaging except for the receiver, which is new but not in the original package.
Dynamite 1/8 on road In-Line Exhaust System - $40
Dynamite 1/10 In-Line Quiet exh - Polished - $40
Dynamite 1/10 In-Line Quiet exh - Black - $40
Futaba R203HF 3ch. micro receiver - $75
This is the Futaba R203HF High Frequency 27MHz Receiver without a crystal.
Designed to be used specifically with DIGITAL Servos only
Designed specifically for the new 3PK system.
FEATURES: High Response FM signal offers significantly improved processing
speed, along with a clearer signal and more precise control.
Incredibly small and lightweight.
Available in 27MHz and 75MHz.
Comes Standard with and will only work with Futaba's New 3PK.
Futaba Crystal set FM 75.610 - $20
Eagle Tree R/C car Data Recorder/Logger - $125
FEATURES: Records information about your R/C car operation such as RPM/speed,
temperature, steering/throttle movement, glitches and receiver
voltage
After racing, simply plug the recorder into a PC or laptop and watch
the included Windows application replay what happened displaying
the car's parameters in a graphic display in real time or use
Excel to further analyze and graph the data
Fully compatible with Win 98SE, ME, Win 2K and XP
NOT COMPATIBLE with Windows 98 Original Edition (Gold), or NT4
even if the PC has USB support
USB plug and play-no new drivers needed
Built-in status LED indicates battery level on power-up, retains race
data without battery
Optoisolated servo monitoring
Ultra-low power consumption, around 35mA
Expansion port for future enhancements
Options include 2nd temp sensor capability (extra temp sensor
not included) pack current/voltage monitoring, g-force, and
exhaust gas temperature and the Electric Expander, ETRP9001
BRP Motor Analyzing Dyno - $75
- Check performance of motors
- Tune motor to track
- Check spring and Brush Settings
- Tune gearing to track
- Test motor amp readings
- load motor voltage reading as RPM reference
- 2 load positions to simulate track conditions
RPM T-maxx/E-maxx Molded A-Arms - 3 packs of purple and 1 pack in blue (each pack comes with an upper and lower arm) - $5 a pack
RB Concepts .12 Piston/Sleeve Set for 3P X12/V12 - # 01700-035 -$50
RB Concepts .12 Pullstarter Assembly - # 01700-151 - $20
Team Orion Micro RS4 Rocket Battery 6V - # 13011 - $15
Team Orion 6.0 Volt Micro Pack 1100Ni-Mh - #13010 - $25
FMA Direct Kokam Lithium Polymer 3 cell 20C Discharge rate 11.1V/2100mAh battery & connector - KOK2100-20C-3S-DNS - $90
FMA Direct 1 Cell Lipoly Charger - FMALIPOCH103 - $15
MIP Tweak Station - #9020 - $30
- This allows you to make sure that your vehicles weight is evenly distributed between the left and right side.
KEEP IN MIND - EVERYTHING IS BRAND NEW![/b]
Fl1pSde 101
Want to Buy / Trade ARCHIVE
Aug 7, 2008 06:57 PM
Fl1pSde 101
Other ARCHIVE
32
Jun 18, 2008 07:21 AM
Fl1pSde 101
Jun 5, 2008 07:10 PM
