F/S: Ford Engine/5 spd transmission/Transfer case. $400
I tried to get the mods to move this over to here in the 4x4 section with no success.
So here's the link to it in parts for sale: https://www.vadriven.com/forums/show...81#post2593881
Means of Contact: PM
F/S: Ford Engine and 5 speed transmission and transfer case. $400
Came out of a 1989 Ford Bronco 2
2.9L V6 - 5 speed transmission - Transfer Case
The transmission is an FM146 - 5 speed.
The engine does not smoke. Runs great. No knocks or ticks.
The transmission shifts perfectly and the clutch is in excellent shape.
The transfer case works flawlessly.
THE DISTRIBUTOR CAP GOT CRACKED WHEN ENGINE WAS REMOVED ($15 part if that)
I removed the transfer case from the transmission prior to pulling the engine/tranny out of the truck, so it is separated from the unit as a whole.
The engine is complete from the pulleys all the way back to the transfer case. And from the oil pan all the way up to the intake.
The engine still has the exhaust pipes and the catalytic convertors attached to it.
(The engine has been sitting inside and out of the weather since removal.)
The transmission also comes with the shifter and shifter boot. (I had to remove it to be able to get the engine/tranny out as a unit.)
The clutch slave cylinder and hose is still connected to the transmission.
There is also a stub section of the drive shaft left on the transfer case because of frozen bolts so I just cut the dang shaft with the sawz- all.
I originally bought the truck for a parts vehicle and pulled the engine, tranny and transfer case to do an automatic to manual conversion in a Bronco 2.
Never got around to doing it.
I also have the pedals to do the conversion that can go with it for no extra charge.
$400 - You take it all with you.
A Picture of the "tag" on the Transmission.
