SR20DET OS Giken Twin Plate Clutch, aftermarket pistons
what up
Derek
Chesapeak va
757-853-7771 work number or PM me
Have got a OS Giken stamped steel Twin Plate clutch for an SR20DET. Has 4,000 miles on it. nearly 95% of its friction material left. Requires the use of a Pulsar GTIR throwout bearing which you can get from nissan. Heres the part number and some info about the clutch.
Release bearing: OS00-0011 or Nissan 30502-1460 Release Sleeve: Nissan 30501-UO200 (or 30501-A6801) for TS2BD
OR
you can space the transmission further from the engine with spacers and use your stock 240 bearing/sleeve assembly.
http://www.osgiken.net/products/racingmultiplate.html
$300 verrrrry neg.
1st set is a STOCK BORE wiesco with piston domes coated. These drop into any stock bore SR20. compression ratio is 9:1 with a .080 cometic hg
$50
2nd set is a .020 over wiesco 11:1 for an SR20. can be brought to 8:1 with a thicker headgasket.
$50
both piston sets are in EXCELLENT condition for the 1,000 miles they both have on them. first set was a project that i scrapped 2nd set was from my race car 10 years ago. Pics of the pistons later tomarrow.
please PM or call at number listed above ask for derek.
Derek
Chesapeak va
OR
$300 verrrrry neg.
$50
$50
marshall
Jan 21, 2008 10:04 AM
