sr20det 6 speed trans
i know its a long shot but i would like to get a 6 speed trans for the s14 if not all offers for another 5 speed ka trans will be accepted thnx guys
Re: sr20det 6 speed trans
The S15 SR20DET comes with a 6 speed so assuming you buy that engine mating a 6 speed tansmission to it would be free (done by Nissan at the factory).
Yury, and Jeff at HeavyThrottle.com can get you a S15 for ~$4500. I'm sure there are other sources too I've just never bothered researching who carries S15s and what they go for. Installing a S13 SR20 into a S13 240 would cost ~$1500...I would assume that installing the S15 SR into a S14 240 would be more time consuming and therefore more expensive, but again I've never looked into it. It's a pretty safe bet though that you'll be spending $7000+ (including buying the engine) to get a S15 SR into a S14 240 plus a little extra for converting from auto.
The S15 does have a variable valve timing system but as Alex said it's called VTC not VVL. VVL refers to variable valve lift (IIRC this is the system used on the SR20VEs, and SR20VETs)
The significant differances between SRs are as follows:
S13 - T25 turbo, 370cc injectors, high port intake. 205 hp, 203 lbs/ft
S14 - T28 ball bearing turbo, VTC, low port intake. 220 hp, 203 lbs/ft
S15 - 480cc injectors, 6 speed transmission, speed sensor in differential. 250 hp, 203 lbs/ft
Each engine inherits the improvements of it's predecessor. For example the S14 keeps the 370cc injectors of the S13, and the S15 keeps the VTC that was added to the S14.
Edit: A little bit of rewording.
[ 03-20-2002, 01:41 AM: Message edited by: SR20VET ]
this post was on another forum and some others i read up on. and like shaminii said it only comes in the s15. i will be replacing my trans soon and have not seen any other 240 swaps with this 6 speed wanted to be diffrenent. all and all it seems like it will be impossible to find one so anyone got a replacement 5 speed for my s14 thnx
