PARTS FOR B18C1
U R
PARTS FOR B18C1
BNIB: G SPORT PRO FUEL RAIL FOR B SERIES HONDA MOTORS.
Fits all years 94 to 01 Acura Integra DOHC 4cyl & 1998 to 00 Honda Civic SI B16A VTEC.
-$100 firm (pick up only)
BNIB NRG B SERIES ENGINE TORQUE DAMPER
Engine Damper mounts in between your vehicle's engine block and firewall to effectively control horsepower and torque. Keep your motor supported as you slam through those gears while adding a nice show piece under the hood. Creates less stress to engine mounts, giving you more power to the wheels.
-$75 firm (pick up only)
BNIB SKUNK2 PRO SERIES INTAKE MANIFOLD FOR 94-01 GSR (B18C1)
The Skunk2 Pro Series Intake Manifold is Styled after the Acura Integra Type R Manifold. Skunk2 used the engineering of the Integra Type R and applied it to and Intake Manifold for other engines, like the D16, H22 and B18C1. For Motors found in the Integra GS-R and Prelude Vtec, the Single Path Intake Runners have a higher volumetric efficiency and will naturally create better combustion. This helps Skunk2 Intake Manifolds to Create 7-15 horsepower by just bolting on to a stock engine. If you have a Turbo System or Aftermarket Cams, The Skunk2 Intake Manifold will help the Engine Benefit even more from the Higher Air Flow.
-$220 firm (PICK UP ONLY)
