need gone asap honda parts / prefer trades
Means of contact:571 208 4586 or pm me here
Price: $obo
Description: b18b1 block (needs honing or bore great for project) 50
was told its type r crank but not sure i am sure its for b series as it was in the block when i got it 60
p30 jdm b16 pistons on rods(rods have scaring where bearing were 50
pr4 ls pistons on ls rods in good condition 40
pr4 ls pistons(bad pistons) on jdm pr4 .73 rods good rods 30
2 rear main seals 25
pr4 b18a1 timing belt used for 35k miles 20
b18 oil pan not tapped 25
2 windage trays 15
oil pick up tube 10 you can get all of the above together for 150 no less
obd2a 97 gsr p72 ecu 80
garrett dsm turbo oil and coolant cooled great working condition 80
air research dsm turbo works great oil and coolant cooled 80
both turbos for 120 obo need gone
95 gsr leather seats grey one tear along the seem where you sit not on the sides some signs of age but good condition 60
walbro 255 fuel pump for 240sx gss 341 part number new ran for 2 days for dyno tune then removed for a bigger pump 75
waste gate no name needs spring and fire ring 38mm 10
carbon fiber 96-98 evo style hood by carbon creations 175
fenders for 96-98 civic red/black car was custom paint so will need repaint 45 each side
96-98 headlights 75 for both
for trade only with cash on your end i have a jdm b16 trans in my car you can see it theres no issues i need an ls trans must be in your car so i can see it working ill do the swap dont worry about that i want your trans plus 80 on top
pics through text anytime
i need stage 4 or 5 b series clutch for 94 or newer with lightened flywheel clutch must be brand new
fuel rail
lightened crank pulley
b series timing/cam gears
lightened alternator pulley
b series into ek mounts/ solids/racing mounts
performance radiator for 99 si with thin fan
good dump tube
1600cc high impendence injectors
walbro fuel pump 255 gss 342
intercooler and piping
t3t4 turbo 57 trim
arp head studs for ls integra and for d15b single cam
Price: $obo
2 windage trays 15
fuel rail
good dump tube
t3t4 turbo 57 trim
