misc. b series parts
Means of contact: text 540-607-7681
Price: $5-60
Description: I have a few misc. b series honda parts. I will not me you, Its not worth me burning my gas to make a $20 sale. Sorry! I can be reached at 540-607-7681 anytime. Do not call me at 1am and do not email me. There are a bunch of idiot scammers on this site, I will not read or reply to emails. Thanks for looking!
Everything is or best offer.
integra ls cams with oem cam gears. (used cam seals are on them) $30
Throttle body gasket set $5
Intake manifold gasket $7
Valve cover seals (go around the spark plug holes) $5
valve seals $10
ls lma's $10
Ignition coil $20
cam seal plug $5
I will sell all the gaskets and valve seals for $25 including mics. small orings, water pump oring, extra bolts, ect. that are left over from a head swap.
everything I have can go for $60
Pictures: [ATTACH=CONFIG]150634[/ATTACH][ATTACH=CONFIG]150635[/ATTACH][ATTACH=CONFIG]150636[/ATTACH]
ILOVEPENIS -- If this line is still here it means you probably didn't fill out the required information correctly and a mod will be locking your thread shortly. You should probably delete it.
Price: $5-60
valve seals $10
ls lma's $10
Ignition coil $20
cam seal plug $5
