LS1, T56, 5.3 and S13 SIKKY Swap Kit trade for SR20det plus cash
Slammedxpert
Means of contact: 757-675-3013
Sikky Kit: $1650 picked up. ALL BRAND NEW, NEVER USED, NEVER OPENED other than to verify parts per invoice.
Ls1 engine disassembled
Had a spun bearing
Have a good crank and sixteen good rods
8 good pistons
No oil pan
No Intake Manifold
Have most of the sensors
Two sets of heads
$700
T56 from a 2001 ss
no bell housing
needs 3-4 billet shaft keys (disassembled to figure out)
$950obo for trans
Sikky Kit Includes:
Aluminum Race Oil Pan V3
7 quart high capacity design
6061 CNC machined flanges from 1/2" material retaining OEM like structural rigidity. (not flimsy like other aftermarket pans)
Rear flange at bell housing allows install of factory dust shields
Baffle and trap doors to prevent oil starvation
New OEM oil pan gasket
Custom Oil pickup assembly
Remote mount filter Kit
-10 AN fittings (4) and stainless braided lines (2)
Remote oil filter base
High quality oil filter
All fittings and hardware
Engine Mounts & Transmission Mounts
CAD/CAM designed CNC machined solid 6061 T-6 aluminum mounts
Custom Urethane Bushings with true isolation
High Grade Hardware Kit
Proper Engine Placement and Axle Alignment
Lifetime Warranty on engine mounts
Trans Mount
CAD/CAM designed
CNC bent steel mount bracket
Urethane bushing
High Grade Hardware kit
Designed for use with the T56 transmission
Lifetime Warranty on transmission mount
Driveshaft
Steel One Piece Driveshaft with high strength 1310 U-joints
NON ABS REAR kit.
Had a spun bearing
8 good pistons
No oil pan
No Intake Manifold
Two sets of heads
$700
T56 from a 2001 ss
no bell housing
$950obo for trans
Sikky Kit Includes:
Trans Mount
CAD/CAM designed
Urethane bushing
Driveshaft
NON ABS REAR kit.
Re: LS1, T56, 5.3 and S13 SIKKY Swap Kit trade for SR20det plus cash
Get at me for sure 571 451 5166
SR20DET red top
Megan tubular manifold
Megan turbo elbow
slightly larger turbo
steel braided turbo lines
Z32 MAF
ECU
Wiring harness
Driveshaft
front mount intercooler
compressions good across all cylinders
SR20DET red top
Megan turbo elbow
Z32 MAF
ECU
Wiring harness
Driveshaft
