lots of parts. garage cleanout k/b/d parts
i have alot of stuff for sale. just stuff laying around. figured id be better off with a little extra cash because it'll get my kswap on the road. i just need a winsheild a rear wheel bearing and tags and its good to go. so here it goes.
contact: pm, or text 304-995-3261.
prices are nogtiable and i am motivated to sell, so feel free to make offers. im tryin to clean out the garage and dont need this stuff laying around.
shipping is at buyers expense
if you would like better pictures of any one item i can text or email them to you.
nx seloniods with a nos purge valve, fogger nozzle, and assorted jets. no lines or anything. $50 dollars for everything
da 15/16 master cylinder $50
dc 1" master cylinder $50
autometer phantom narrow band airfuel gauge $25
d series flywheel (clutch include but dont know how well it holds) $30
obd0 pr4 ls ecu $50
eg cluster with tach 200407 miles $60
da gsr cluster 269606 miles $75
type s intake mani and throttle body, no sensors $125 for both or $75 each
d16y8 intake mani $40
b18c1 intake mani $50
d16 skunk 2 proseries intake mani (clean clean) $sold
Civic half rad oem replacement, used for like 3 months $30
k20 type s flywheel and clutch set 70k miles $50
k20z1 oem valvesprings no retainers just springs 70k miles $40
k20z1 headbolts oem 70k miles $30
k20z1 oem cams 70k miles $200
k20 oem oil cap $15
k20 oil pressure sending unit (warning light) 70k miles $20
oem type s throttle cable $25
oem k20z1 fuel rail $20
k20 starter $sold
type s plug cover (my brother in law was bored and painted it) $15
rsx multiplexor/fuse box (03 type s) $50
rsx skunk2 rear lower tie bar this came off of a type s that was sitting for a while. it is missing the skunk2 plate (i rivoted it to the firewall of one of my old civics dont know why) and one of the bolts are rusted but its still functional. $30
d16z6 fuel rail oem $15
civic power steering fluid resivor $15
d series axles (2 set) good boots and joints $50/set
some no name solid mounts for 90/91 or 92/93 gsr, will not fit 92/93 non gsr. the driver side timing belt mount was welded to the block mount. so it is one unit from the block to car. still good mounts though, didnt vibrate bad on my 92 gsr either. $75
92/93 non gsr integra innovative kseries transmission mount. this is just the tranny mount, it has a grey insert bushing. this will fit the 92-93 non gsr integra only. i do not know why but the 92-93 gsr drive side mount pocket is the same as the 90-91 integra. the 92-93 non gsr is different. mine is a gsr so i couldnt use this mount. its got some nicks and marks from trying to use it. but nothing to affect the usibilty of the mount. $100
garrett tr0759 a/r .48 2g eclipse t25 turbo. minimal shaft play. $100
obd0 pr4 ls ecu $50
k20 oem oil cap $15
k20 starter $sold
Re: lots of parts. garage cleanout k/b/d parts
sorry been sick and working alot (shitty combination lol). i do not have a fpr. if i did it would be easy and cheap to mail due to size but dont have one.
spnamnt
Engine / Exhaust / Drivetrain
38
06-16-2010 05:28 AM
