LOTS OF H AND F SERIES PARTS, TAKE A LOOK
TEXT 410-490-5301
JDM F20B DOHC VTEC BARE BLOCK WITH MAINS, NEEDS BORE AND HONE 150$
JDM F20B DOHC VTEC CRANKSHAFT AND RODS 200$
F22A BARE BLOCK WITH MAINS 100$
F23A CRANKSHAFT AND CON RODS, MICROPOLISHED AND BALANCED 250$
F20B SIR-T 310CC OBD2 INJECTOR 100$
H23A JDM 55MM MAINS BARE BLOCK NEEDS BORE AND HONE OR SLEEVING 200$
OBD2 8PIN H22/H23A/F20B DISTRIBUTOR, ALMOST BRAND NEW, 100
H22 LOWER AND UPPER TIMING BELT COVER, 20 EACH
F20B DOHC VTEC BLUETOP TIMING BELT #14400-PCB-004 BARELY USED 3000 MILES ON IT, 80$ PAID 150 FOR IT
H22 TIMING BELT OEM HONDA BARELY USED 40$ # 14400-P13-014
H22A ALUMINUM PM5 AC COMPRESSOR BRACKET 40$
H22A POWER STEERING PUMP 60$
H22A AC COMPRESSOR 60$
H22A HYDRAULIC TIMING BELT TENSIONNER 20$
H22A OBD1 AND OBD2 ALTERNATOR, 50$
F20B OIL PAN, PICK UP AND WINDAGE TRAY, 100$ WILL FIT H22/H23
H22A OIL PUMP 75$
H22A OEM INTAKE MANIFOLD MAKE OFFER?
H22A/H23/F20B VTEC SPOOL VALVE AND SOLENOID 50$ SOLD
H22A WATER PUMP 40$, BARELY USED
H22A OEM HEAD BOLTS, 20$ FOR SET, USED
F22A SOHC BARE BLOCK WITH MAINS 100$
B16/B18 M/T STARTER OEM 50$
B SERIES HYDRO INTERMEDIATE SHAFT 50$
I HAVE MORE PARTS,TEXT OR CALL 410-490-5301 IF INTERESTED OR WANT PICS OF ITEM
H22A OIL PUMP 75$
