huge lot of honda parts. b18, turbo s2000 seats, rota
Means of contact: 540-742-4550
Price: $
Description: this is all the honda parts that i have gotton over the years i know i have more just have to add them later when i think of them. everthing is best offer no lowballers this stuff can set at my house till i die no reason for me to sell at all just need some extra cash to finish my build also i am up for trades. i will combine stuff for a good deal. i am fair with all my prices just offer away. best way is to text me for more info on stuff. 540-742-4550
j1 trans just rebuilt. needs top bearing-300
ys1 trans-350
rc injectors 550-225
d15 and b18 stock injectors-20 each
stock manifolds for d15 and ls b18 b20-45 each
ac and engine fans-10 each
d15 and b18 valve covers-25 to 100
civic and integra axles-50
2 front bumbers crx and a 94 civic 4 door-75
lots of engine and head and intake sensors tps ops .ect. ect
b18 clutch stock and a b18 6 pluck clutch both go to a small spline- 75 and 90 for 6 pluck
2 b18 half shafts came off a 90- 93 integra-60
DA mesh powerdcoated rims with good tires-400
92-95 single cam trans hydro-10
air/fuel ratio oil pressure both autometer and a water temp and a OBX boost gauge-30 each
3 b18 ls heads- 75 each
3 d15 heads- 50 each
zc head- 75 SOLD
sohc vtec head 3 one complete other missing a couple of things 75 for the one missing parts and 150 for both of the other ones to make one good one
d15 engine out of a crx bottom end needs rebuild-100
92- 95 single cam 0bd1 harness was a automatic harness-75
b18 obd1 engine harness automatic-50
0bd0 b18 engine harness 5 speed-80
0bd1 p75 ecu-80
crx/civic resistor box-25
obd0 dual point engine harness-50
b18 ls rods-50 for hole set
b18 water pumps- 30
b18 oil pump-45
b18 oil pans-50
lots of b18 and d15 engine mounts-20 each
lexani rims 17inch almost brand new used 200 miles-600
DA carbon fiber hood-350
b18 0bd0 dizzy-90
blue DA door panels rear blue seats and black dash-make offer
3 d15 starters-45 each
crx rear sway bar from an si-75
d15 vtec camgear and cam-20
d15 and b18 headers-50 each
aem fuel rail and aem reg-make offer
b16 intake mani blox-trade only
ls mesh snowflake rims good tires-300
b18 srp je pistons 9:0:1 200 miles on them look new still-make offer
b18 eagle rods and they are arp big bolts in them-200
88 civic hath shell not one dent in the whole body no rust. need rear springs and shocks might put some in if i have time from the front seats back there is no platice or rear seats just some battery cables for the battery. needs hood also-500
blue s2000 seats have ef or crx seat rails on them-600
b16 head can make complete if needed have everthing for lsv-make offer on what u need
civic eg trunk white-50
b18 bottom end complete-300
b18 complete engine 90k miles and a b20 head on it-500
comption clutch flywheel lightweight 9lbs goes to a d series-150
type r intake manifold-150
rota gt3 rims one has a small bend and the paint is chipping off them-make offer looking for other rims plus cash on my end if needed
crx parts car text will needs and it is a dx model
2 brand new stock bore head gasket ls non vtec-45
b18 block with new micropolished crank and brand new bearings and arphead bolts for ls head also have a fully buit ls head.it is a real JGE head has both stamps from them. just missing cams-1200 but looking for trades on other stuff
b18c1 brand new jdm gsr pistons and brand new ACL mani bearings. comes with oil and water pump missing rings on one of the pistons and also missing the oil pan.
i prob have other stuff will list later as i go through it all and take pics of everthing that i have
mani trades looking for is a good 500hp turbo 60 to 63 somthing like that or a little bigger.
also need a nice turbo mani blox,nuken,p fab. something of that nature.
Pictures: http://s1221.photobucket.com/albums/dd480/nick-to-go/
Price: $
ys1 trans-350
zc head- 75 SOLD
0bd1 p75 ecu-80
b18 water pumps- 30
b18 oil pump-45
b18 oil pans-50
b18 0bd0 dizzy-90
Re: huge lot of honda parts. b18, turbo s2000 seats, rota
i hate threads like this... too crammed and not organized... and photobucket sucks to scroll through
i cant even read all this great stuff. good luck though
