HONDA PARTS FS/FT (always updating)
Winchester, VA 22602
540-542-9081call/text
Cash or trades
Serious callers only. Dont waste my time Make me an offer if you dont like my prices. Low ballers will be ignored. Everything is priced for pick up only. If you want me to meet up then your gonna pay for my gas!
PLEASE DONT CALL OR TEXT ME UNLESS YOU HAVE CASH IN HAND OR TRADES!!!!!!PLEASE DONT CALL OR TEXT ME UNLESS YOU HAVE CASH IN HAND OR TRADES!!!!!!PLEASE DONT CALL OR TEXT ME UNLESS YOU HAVE CASH IN HAND OR TRADES!!!!!!
- Built B20z block. Stock pistons and rods. Knife edge crank, acl race bearings, arp headstuds, brand new rings from honda, type r oil pump and water pump. Comes with brand new cometic headgasket, bnib arp headstud and brand new blackworks vtec kit. All new oem honda gaskets. Block was blueprinted and has paperwork. $1200 dont even try lowballing me the crank alone was $500
- Skunk 2 pro 2 cams with 5000 miles on them (bseries vtec) $400 obo
- Brian Crower stage 1 cams (bseries vtec) $300 obo
- B16 LSD cable trans 40-60k mint! $600obo
- Banks turbo. Came off a deisel truck but can be modified for anything. 4 bolt manifold flange and 6 bolt downpipe. 0 shaft play $100
- B18b1 block for parts
- B20b block for parts
- B18c1 block for parts
- jdm sport intercooler $50
- b18 axels make offer
- type r valve cover 120$
- Brand new tri-y header for gsr $200 obo
- Bnib B16a arp main stud kit $80
- Brand new XTD stage 3 sprung clutch kit with fidanza flywheel for cable trans $400 obo
- stage 4 6puck sprung clutch with pressure plate(for cable trans) $100
- Brand new stage 1 exedy clutch and pressure plate never been used (for hydro trans) $150 obo
- H22a complete head with valve cover $250obo
- 97 sh H22 head complete with intake mani $350obo
- H22 cams with gears $75
- 100% complete h23 intake manifold MAKE OFFER
- 2 B18 heads $40 each need rebuilt
- Good B20b crank $100
- Good B18c1 crank 100$
- Brand new 70mm Holley tb with sensors $250
- Used Blox 68mm tb with sensors $100
- Gsr arp headstuds used once $100 obo
- Aem three way adjustable blue cam gears for bseries $100obo
- Ebay brand sohc adjustable cam gear blue $40
- Fully adjustable skunk2 coilovers only have 100 miles on them. Came off a da integra but may fit others $600
- Gsr and ls intake manifolds $60 each
- Ported and polished B18a1 intake mani $75
- 00 si gauge cluster with 200k on it but works fine $150
- 00 si rear sway bar with hardware $60
- set of struts for ef/da/crx 2 tokiko blue and 2 kyb gr-2 $60
- Golden eagle blue fuel rail bseries $120obo
- 2x 92-00 civic/integra front upper strut bars $40 each
- ef/crx/prelude red aem cold air intake $120
- BRAND NEW from honda b16 black valve cover $75
- Almost brand new (6 months old) 16'' white rota slipstreams. 205/50/16 tires with 75% tread $600
- Crx pass seat only really clean no rips BEST OFFER
- Obd0 pr3 b16 ecu $50
- Obd0 pr4 ecu $40
- ef sedan full stock exhaust welded for bseries $80
- ef/crx bseries shift linkage $50
- Aftermarket bseries cam seals 25 each
- Ef/crx innovative front cross member with polyurethane inserts for the traction bar. Has mounts for half size rad $150obo
- 90-93 integra grey seats good shape $100obo
- ef sedan black door panels with manual windows ok shape $40
- brand new half size aluminum radiator with slim fan $100
- 2 12'' 1200 watt sony xplodes with 1000 watt planet audio amp $200
- 600 watt alpine amp 75
- 800 watt memphis amp $100
- 400 watt pheonix gold amp $50
- b16/b18/gsr pistons, rods, oil pumps, water pumps etc
- wiring harnesses for dc/da/ek/ef
- b and d series injectors obd1/obd2/obd0
- b and d series fuel rails
- ek coupe/hatch oem tweeters $40
- 5 panel wink mirror $40
- Civic hids 8k $30
- EG foglights $40
- 96-00 grey civic floor mats in good condition $50
Cash or trades
- Obd0 pr4 ecu $40
- Civic hids 8k $30
- EG foglights $40
VADRIVEN IS WHACK!
Re: HONDA PARTS FS/FT (always updating)
you got a picture of the bike rack? what feet are on it now? will it fit a eg without modification? very interested and willing to drive if its in good shape and not stickered up. also might be interested in that ls trans if i can't find a gsr or b16 trans worth having. i get my taxes in on the 15th i'll be in touch
VADRIVEN IS WHACK!
ok, i may be able to get the stickers off without too much damage to it, do you happen to have also a 5 speed b series starter or 94-01 integra or 99-00 si linkage for b series do you?
Yeah ive heard wd40 takes stickers off easily, but i do have a brand new starter and linkage if you want those too
