Fully Build BMW 2.8Liter 8.5:1 Comp, by CNC Engine Dynamics in Winchester va
Means of contact: mruppert@aol.com ( Please email me i dont check this forum alot )
Price: $7000 FIRM
Description: I have a built 2.8L BMW motor for a E36 body style or E30 swap
Not much to say i will let the parts speak for them self's
MADE: 600WHP 473WTRQ @ 24PSI ( This Dyno was NOT fully tuned )
RAN THE 1/4 IN: 10.66 @ 132.53MPH
Motor: 50miles ** Always use Motul v300 15w50 ** $7000 FIRM
- M50 o-ringed block
- M52 Crankshaft ( 2.88 Liter Motor )
- S50 Head
- S50 Cams ( 76k miles on cams / tray's / Lifters )
- Supertech valve springs
- Valve Job and new Seals
- ARP2000 Head studs
- ARP Main studs
- Manley 84.5mm 8.5:1 Comp Forged Pistons
- Eagle ESP Forged Rods
- VAC Race chains
- OEM BMW Rod / Main Bearings
- OEM Oil Pump with Tack'ed Nut
- Dr.Vanos StageII Unit
- OEM Coil packs
- NEW NGK 4554 spark plugs .020 Gap
- M50 Intake manifold with ICV adapter epoxyed / wire tied in ( Did this for boost )
- E34 Oil Pan with -10an Oil Drain Feed
- Factory Throttle body
- Factory OBD1 Fuel rail and Fuel pressure
- UUC Under Drive pully's: water pump, power steering pump
- Stewart Water Pump
- VAC Billet Oil filter housing
- Peterson Remote Oil filter mount runs a Mobel M1-110 or 111... I dont remember the number its for a 69 Camaro
- 12"x 8"x 2" Oil cooler
- Metal Coil pack cover with DEI gold heat reflective stuff
- 2 New Knock sensors
- New Cam sensor
- New Crank sensor
- S50 Intake manifold
- S50 Throttle body
- Power steering pump
- Alternator
- This Motor also has EVERY nut, bolt, dowl, seal and gasket... everything that could be replaced was done so with BMW New parts over $1900 spent at bmw in just that stuff.
** I WILL DELIVER THIS MOTOR UPTO 400 MILES FROM 22066 ZIPCODE IF MY ASKING PRICE IS MET, AND IF YOU ARE FARTHER AWAY IT CAN BE DONE FOR AN ADDITIONAL COST. ALSO MUST HAVE ENGINE HOIST ON HAND TO TAKE IT OFF THE TRUCK **
Pictures:
MOTOR DURING BUILD PROCESS:
Price: $7000 FIRM
- S50 Head
- ARP Main studs
- VAC Race chains
- OEM Coil packs
- New Cam sensor
- New Crank sensor
- S50 Throttle body
- Alternator
Pictures:
Re: Fully Build BMW 2.8Liter 8.5:1 Comp, by CNC Engine Dynamics in Winchester va
yes the motor is built for boost.. runing a GT3582R.. which i still have the turbo manifold and turbo, and tune.. we could setup a deal for all of it.
