E30 M30B34 Swap (or 5/6/7 series engine/transmission replacement)
Location: Chesapeake Means of contact: PM/Text-Call/Email: Here/7573384564/rccuffee@vt.edu (txting is best) Price: 1500$ Description: I have a complete swap for the e30. this includes: engine: m30b34 from guten parts service: new custom e30 mounts new rear main seal new thermostat new cam oiling bar bolts and crush washers new "duck" gasket for the rear of the head new oilpan gasket new waterpump and gasket new intake manifold gaskets new oil filter and gasket new vc gasket new tb gasket(no installed yet) new bosch ign rotor new rad hoses, upper and lower e34 E28 radiator b35 intake mani b35 thermostat housing e34 pan/pump dist cap b35 starter b35 exhaust manifold e34 down pipes x-y pipe G260 transmission m5 clutch/pp 535i flywheel 535i slave cyl new pilot bearing all new transmission bolts new clutch slave 179 dme Pictures: https://fbcdn-sphotos-a.akamaihd.net...4_619457_n.jpg https://fbcdn-sphotos-a.akamaihd.net..._3777099_n.jpg https://fbcdn-sphotos-a.akamaihd.net..._1721803_n.jpg https://fbcdn-sphotos-a.akamaihd.net..._6794257_n.jpg https://fbcdn-sphotos-a.akamaihd.net..._3751166_n.jpg Only thing you need is engine/trans bushings (i was gonna use poly) and finish exhaust. if you have a 5spd m20, you can reuse the transmission crossmember, hydrolic lines and driveshaft. You can also use the harness just extend some wires. All sensors on the m30 have been converted to e30 type. ILOVEVAGINA -- If this line is still here it means you probably filled out the required information correctly and a mod will be looking at your thread shortly. |
Re: E30 M30B34 Swap (or 5/6/7 series engine/transmission replacement)
still have it
yep
once more
anybody interested?
ups yo
